Empty VSE preview for scene strips with OpenGL preview + Rendered settings #52050
5 Participants
Reference: blender/blender#52050
ubuntu 14.04
AMD Athlon(tm) II X4 630 Processor × 4
Gallium 0.4 on AMD RS780 (DRM 2.43.0 / 4.4.0-83-generic, LLVM 3.8.0)
64-bit
1.7gb ram
Broken: 2.78c
e92f235283
Worked: none
create an empty scene and put ate compositor
create in the blender file multiple scenes, each scene with diferente group characters and group props linked after the creation of the composite scene.
if you put the scenes on the sequencer at the first scene (named composite for example) you will see nothing on sequencer view, should be able to see even if you create first, but it only works if you create the composite scene later. so you can not link anything new without deleting and creating a new composite scene.
Added subscriber: @ivampretti
Added subscriber: @mont29
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Sorry, but what is missing?
Added subscriber: @Blendify
Please add a blend file that shows the error.
did it! I just don know if the attach worked!
Added subscriber: @fablefox
Hi,
If the attach work there will be a button that let people download the file. An example of a bug report with attached .blender file is here #52149 . Note the err3d.blend
Link Error.blend
char1.blend
here the attached files
same problem with the 2.79 test build Date: 2017-08-01 17:31 Hash:5e9132b3b7d.
At the sequencer view you should see a monkey linked by scenes. Char1.blend is the source file where the monkey is a group and Link Error.blend is a general link file.
Added subscribers: @Sergey, @ideasman42
Thanks for the files…
Only weird thing here (and afaict, totally unrelated to linking) is that, in VSE preview settings, the combination of 'Rendered' preview with 'OpenGL Preview' option enabled gives empty preview.
@Sergey, @ideasman42, do you guys know what should happen in that case?
Link Problem!to Empty VSE preview for scene strips with OpenGL preview + Rendered settings@mont29, i'm not sure what is motivation in current code, but think OpenGL Preview is a historical redundancy from times when it was the only option to switch between final render and some shaded mode. Think now we need to remove that option and make internally things behave like:
In the middle of something else now so might sound confusing, but hope you got the idea :)
@Sergey thanks, sounds clear enough to me :)
Guys, at the blender 2.79 rc2 the problema steel remains. The only change was that the sequencer screen got black. Same files sended before, but I alredy tried to remake the files at the rc2 and the problem is the same.
@ivampretti since there is no light at all in your scenes added as strips in the VSE… no wonder they render pitch black ;)
Thanks a lot!
