regression can't open file in 2.79 (crash) #52816
5 Participants
Reference: blender/blender#52816
Windows x64
Broken: 2.79
Worked: 2.74 to 2.78
Some files get an instant crash when trying to open in 2.79
Try to open this file saved with 2.74
crash visibility layer 274.blend
Added subscriber: @bliblubli
Added subscriber: @mont29
Cannot confirm that here on linux64, with a debug build of current master… can you check if you still get crash with the latest build from our buildbot?
Added subscriber: @LazyDodo
I can repro when i enable the page heap on windows ( don't have time to extract a stackdump now sadly) so i'm pretty sure asan will catch this on linux as well.
allright had some time, here's a stackdump
looptri- [x] is pointing to uninitialized ram.
This smells like threading issues again, pretty sure running with
-t 1
option is enough to get rid of the crash?Will check on this more tomorrow, but could not reproduce the issue even with an debug/asan build here with master code.
Stack dump is from latest master, can confirm -t 1 gets rid of the crash.
Added subscriber: @mano-wii
I made a weird change in the code that seems to solve the problem:
Apparently, since the condition: "
if (dm->looptris.array) {
" of thedm_getLoopTriArray
function is out of the thread's mutex_lock, thedm->looptris.array
can be used before being "fully written".My solution was to leave
dm->looptris.array
NULL
during the entire process of creating the looptris array.(if I avoided malloc within
DM_ensure_looptri_data
would be more correct)Uh… good point didn’t thought about that kind of concurrency issue :P
Will try to find more generic way to do that (including other DM types), but that's clearly the way to go indeed.
This issue was referenced by
9591b5f618
Note that
9591b5f618
is tentative fix (based on @mano-wii's work), if one of you guys could confirm it fixes the issue would be great. ;)Added subscriber: @Sergey
Well, it seems @Sergey came across the same bug, and found a workaround for adding another mutex to
dm_getLoopTriArray
->1a4442b3db
But applying only your solution also solves the bug
Tested with latest master, no more crash
Thanks for the quick fix, but maybe only one fix would be enough? Don't know if the 2 fixes together may decrease performance?
