AMD Threadripper not working well with Blender #53068
12 Participants
Reference: blender/blender#53068
AMD threadripper 1950x
X399 AORUS Gaming 7 motherboard
64 gb Ram
Running latest chipset drivers + up to date bios
Windows 10 64 bit running on gtx 970 GPU
**Blender Version 2.79
Broken:
5bd8ac9
rendering large scene takes hours before render proces starts
To reproduce this problem, you need to load a large scene like the production demo scene from the blender benchmark. If you use the default performance settings it will take more time then rendering the scene with a low amount of threads.
the difference is huge. Default settings ( 32 threads) can slow down the rendering proces with 2 hours. Using 4 threads only takes minutes.
The more RAM a scene has, the more problematic this issue is. The difference in the production benchmark is 2 vs 7 minutes. The benchmark scene is +/- 10 GB Ram. If i render a scene with 30 GB ram it is 4 minutes vs 2 hours
Added subscriber: @RobTuytel
Threadripper not working well with Blenderto AMD Threadripper not working well with BlenderAdded subscriber: @FloridaJo
Hello Rob.
Can you go to this page and follow the instructions for installing the Microsoft Process Explorer
to better show the threads running during that process?
https://superuser.com/questions/462969/how-can-i-view-the-active-threads-of-a-running-program
I created a video including microsoft Process Explorer.
if you need more details, let me know. : https://www.youtube.com/watch?v=DWyLEBmS8t8&feature=youtu.be
Added subscriber: @brecht
Which parts of the render are slow? The video shows just the synchronizing objects stage, is BVH build slow too, and path tracing?
In the video I think it's the OpenMP threads doing a lot of the work. To determine if that's the problem specifically, you can run Blender from the command line with OpenMP threads disabled or reduced, and see if that helps:
At this point in the video the synchronizing objects stage slows down and takes around 2 hours before it starts with the BVH and path tracing.
The BVH and path tracing runs fine, even with the 32 threads.
Did not work, still freezing. I included a new video to show the difference if i reduce the threads to 4: https://youtu.be/vUe1IXLb7Uk
Added subscriber: @SteffenD
It doesn't look like it's the CPU.
You may want to see if it is a GPU bottleneck.
GPUview is the tool for that, a description of it is here;
https://graphics.stanford.edu/~mdfisher/GPUView.html
For SDK that has GPUview for Win10 is here:
https://developer.microsoft.com/en-us/windows/downloads/windows-10-sdk
You want to make sure the Windows Performance Toolkit is checked on install.
@FloridaJo, the GPU is not involved in the synchronizing objects stage, so I doubt it's causing issues here.
The Cycles side of synchronizing objects is single threaded, so not so likely to cause the issue by itself. It would be useful to test if the same issue happens when rendering with Blender Render. There's various modifiers using multithreading, using either the task scheduler or OpenMP. I still suspect subsurf using OpenMP the most, but
OMP_NUM_THREADS
should have affected that.Intresting result when doing a blender internal benchmark test. I used an 11 GB ram scene on my 4770K and threadripper workstations.
When pre processing the scene, the threadripper is equal with the 4770K. As aspected, the threadripper renders faster as well. Seems like there is no issue with the internal render engine.
When using cycles benchmark scenes, the threadripper is always slower when pre processing the scene. Not only slower, it freezes the whole system for a long time. This only counts for large scenes. Under 10 gb ram it is almost not causing issues
I can make a full lengt comparison video to show the difference in systems if you want.
@brecht I'm not sure he did the OpenMP test as you described.
The video showed him changing threads in the UI as opposed to a command line command. Is that the same?
Rob, can you verify that you ran this in command line?
The latest video was a comparison between 4 and 32 threads. I tried the console boot, but no difference.
Here a video: https://youtu.be/0Cp6WwREWwA
@RobTuytel Okay, gotcha.
Added subscriber: @candreacchio
Does it work if you unpack the textures first?
The first time i tried to render the scene was unpacked. After hanging for hours i started using all the benchmark files on the blender website and comparing this with my intel system. On this point i saw a significant difference between the threadripper and my intel sytem. Not on the small ones like the BMW, classroom, but the production benchmark and my own scenes. In my opinion most of the threadripper tests where done on these scenes, and not large scale RAM scenes.
Added subscriber: @Sergey
@Sergey, is there a machine with a CPU like this in the Blender Institute?
@brecht, we don't have threadripper at the studio, only Ryzen 7 1800X.
Some other questions / ideas to troubleshoot the issue:
I checked all of them, only the Ubuntu option left. However, i can provide the studio with a threadripper system for trial & error, just let me know.
I included a benchmark test, http://www.userbenchmark.com/UserRun/5496362 still trying to figure out what is wrong
Added subscriber: @Ton
AMD was meant to send us (Blender Institute) a threadripper in July already. I reminded them again what happens with it.
Loaning us your system I wouldn't recommend. Not only because we can't immediately work on it (might take weeks or a month), but also because we probably want to install fresh OS'es on it.
Brecht and Sergey are both on the conference this week. Maybe it's fun to bring the system to the new "hackerspace" room there, and check of if someone has time to investigate it.
Right, I'd be happy to debug it at bconf. Remote desktop access would work as well at some other time.
We've just received a beefy system with Threadripper! Testing started :)
So nice!, now burn the CPU with some crazy scenes to find out if there is something wrong with scene buffering.
All our standard benchmark files survive. Performance is good. We don't have time now to restore or test production files.
It would go much faster if you would share a case, or tell us how to produce a case that's slow? Use one of the benchmark files, duplicate stuff or so?
Added subscriber: @rob
Managed to redo system becoming frozen at some point during synchronization after BIOS update.
Currently suspecting SpinLock to cause this. Experimented with alternative SpinLock implementation and it seems to solve the issue to me.
@rob, please do the following:
blender-orig.exe
(this is unmodified version of current master, just to confirm that the issue happens for you using my builds -- this build is done by a newer MSVC than the official releases, so that might matter)blender-fix.exe
and see if that solves any performance issues.Note that there is no CUDA support in this builds.
EDIT @rob, did you check whether you've got same freezes when rendering from Linux LiveCD?
Setting priority to incomplete since we are awaiting more feedback now.
@Sergey wrong Rob, try @RobTuytel
Added subscriber: @intrah
I can confirm this fix works!
Thanks a lot for solving this problem.
Added subscriber: @Blendify
@Sergey gave two fixes can you say which one fixed the issue?
Blender-fix solved the issue
This issue was referenced by
55696b56d9
Added subscriber: @VincentMarini
@Sergey
Great job identifying the problem and handling it. I can also confirm this works.
Unfortunately there is a handle leak somewhere in there.
I've taken to restarting my threadrippers every 12 hours or so to clear out the handles, but if you could fix this too that would be awesome.
Thank you so much for what you've already done.
Removed subscriber: @intrah
Please report a new bug report
Strike that. CPUID and AMD Ryzen Master were running at the same time. Without them it maintains about 47,500 handles for hours. My bad.
Added subscriber: @MknowlesNC
Is there any other way to get blender-fix.exe other than FTP. I tried that but I apparently don't have credentials.
I have a threadripper 3970 and Blender runs very sluggish with large models 3M+ verts. Just panning, zooming, etc. Not much different than my old PC with an intel i7 processor (8 years old). Rendering is fine... very fast. Probably due to the Nvidia 3090.
Thank you!
