Import issue with two alembic file sequences #53884
Closed
opened 2018-01-24 14:19:18 +01:00 by hidenori saito · 15 comments
linux mint 18.3 windows10
2.79
I tried to import two alembic files exported from realflow, foamParticle and waterMesh, but only one side will be displayed and it will not animate.
realflow
particle only
mesh only
When reading mesh after loading particle
abc_files.zip
Read two abc files
**System Information** linux mint 18.3 windows10 **Blender Version** 2.79 **Short description of error** I tried to import two alembic files exported from realflow, foamParticle and waterMesh, but only one side will be displayed and it will not animate. realflow ![screenshot008.png](https://archive.blender.org/developer/F2009794/screenshot008.png) particle only ![screenshot005.png](https://archive.blender.org/developer/F2009800/screenshot005.png) mesh only ![screenshot007.png](https://archive.blender.org/developer/F2009809/screenshot007.png) When reading mesh after loading particle ![screenshot006.png](https://archive.blender.org/developer/F2009816/screenshot006.png) **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps [abc_files.zip](https://archive.blender.org/developer/F2009853/abc_files.zip) Read two abc files
Author
Added subscriber: @hisai
Member
Added subscriber: @lichtwerk
Member
could you share the .abc files here please?
Author
[realflow_abc.zip](https://archive.blender.org/developer/F1969272/realflow_abc.zip)
Author
Uploaded file simulated with realflow10
Member
Particles (HY_Foam01_00000.abc - HY_Foam01_00031.abc) seem to be imported correctly - and are animating on my side?
Are you sure you have checked Is Sequence in the Import Alembic options?
Not sure about the mesh part, this seems to be written in .bdc format which is not something blender can import afaik (see here )
Particles (HY_Foam01_00000.abc - HY_Foam01_00031.abc) seem to be imported correctly - and are animating on my side? Are you sure you have checked `Is Sequence` in the Import Alembic options? ![#53884.png](https://archive.blender.org/developer/F1969966/T53884.png) Not sure about the mesh part, this seems to be written in .bdc format which is not something blender can import afaik (see [here ](http://support.nextlimit.com/display/rf2015docs/FAQ+-+Caronte))
Member
note though that I do get messages like this:
BLI_assert failed: /lichtwerk/01_projects/0000_HACK_BlenderSourceDevelopment/HACK_Produktion/11_Git/blender/source/blender/alembic/intern/abc_object.cc:301, xform(), at 'false'
AbcObjectReader::xform(): unable to find IXform for Alembic object '/particles'
note though that I do get messages like this: ``` BLI_assert failed: /lichtwerk/01_projects/0000_HACK_BlenderSourceDevelopment/HACK_Produktion/11_Git/blender/source/blender/alembic/intern/abc_object.cc:301, xform(), at 'false' AbcObjectReader::xform(): unable to find IXform for Alembic object '/particles' ```
Author
It seems that the bdc file will be output to a separate folder after putting this check in the screen shot.
How about thinking it is irrelevant to this case?
I checked "Is Sequence" and loaded it.
realflow
particle only
mesh only
![screenshot003.png](https://archive.blender.org/developer/F1972231/screenshot003.png) It seems that the bdc file will be output to a separate folder after putting this check in the screen shot. How about thinking it is irrelevant to this case? I checked "Is Sequence" and loaded it. realflow ![screenshot008.png](https://archive.blender.org/developer/F1972292/screenshot008.png) particle only ![screenshot005.png](https://archive.blender.org/developer/F1972274/screenshot005.png) mesh only ![screenshot007.png](https://archive.blender.org/developer/F1972278/screenshot007.png) When reading mesh after loading particle ![screenshot006.png](https://archive.blender.org/developer/F1972282/screenshot006.png) ???
Member
@hisai: maybe I am missing the obvious, but the provided zip only contains the foam/particles (HY_Foam01_00000.abc - HY_Foam01_00031.abc)? Where is the mesh part?
Author
sorry. .
It seems that I uploaded a mesh file by mistake.
meshes.zip
sorry. . It seems that I uploaded a mesh file by mistake. [meshes.zip](https://archive.blender.org/developer/F1987364/meshes.zip)
Sybren A. Stüvel was assigned by Philipp Oeser 2018-01-26 18:55:37 +01:00
Member
Added subscriber: @dr.sybren
Member
OK, can confirm both issues
  • when importing meshes, then particles --> both are visible, but meshes dont animate anymore
  • when importing particles, then meshes --> only particles are visible
@dr.sybren : mind having a look?
OK, can confirm both issues - when importing meshes, then particles --> both are visible, but meshes dont animate anymore - when importing particles, then meshes --> only particles are visible @dr.sybren : mind having a look?
Please update the description of the issue so that it's complete, example files and all. That saves people (like me) from having to read through all the comments and from figuring out which files are relevant.
Sybren A. Stüvel changed title from dosent import two alembic file to Import issue with two alembic file sequences 2018-02-13 15:26:37 +01:00
This is fixed in 09c88fed1f
This is fixed in 09c88fed1f58
Reference: blender/blender#53884
