Changing non-active render layer node "layer", changes the "layer" of active one as well. #53950
Reference: blender/blender#53950
Broken:
7b675e0dc4
(HEAD)Worked: 2.79
By changing one render layer node I end up changing the layer of another node as well.
compo.blend
And change "layer" of the left-most node. It will affect the right-most node as well. Note, do not select the left-most node, change the value by directly clicking in the pulldown "layer" menu.
This issue only happens if the active node is not the one I'm trying to change.
Added subscriber: @dfelinto
If I do the change via Python I don't have this problem:
Added subscriber: @ideasman42
@ideasman42 could you take a look at this?
This seems related to the USE_ALLSELECT causing
CompositorNodeRLayers_layer_set
to be called twice:ui_selectcontext_apply
.This issue was referenced by
807713e4f2
Note that 2.8 was changed from master, so editing the selection was always enabled.
Logically there is no bug here since this is exactly what the option was intended to do.
Reverted the change in 2.8 to use Alt (as master does).
