Severe problem with multiple instances of a library (save and reload) #53977
Reference: blender/blender#53977
Linux Mint 18 Sarah (Ubuntu 16.04.3 LTS)
Broken: 2.79
5bd8ac9abf
When renaming a library filepath to match another already linked, blender mixed libraries.
Example : lib_v01.blend, other_lib.blend and lib_v02.blend are linked in a blendfile (the link order is important).
When I rename lib_v01.blend to lib_v02.blend, save and reopen, Blender "merge" the multiple instances of lib_v02.blend.
But one of the Suzanne is now "attached" to other_lib.blend (instead of lib_v02.blend), and obvioulsy Blender doesn't find it.
lib_v02.blend
lib_v01.blend
other_lib.blend
Added subscriber: @g-lul
Added subscriber: @zeauro
Sorry. But I don't understand what behaviour you are expecting.
You linked one suzanne from lib_v01, one suzanne from lib_v02 and one sphere from other_lib.
You renamed lib_v01 and only lib_v01. You did not rename other_lib. You did not do anything to sphere.
So when .blend is saved and reloaded, why do you expect link to other_lib to be removed ? Sphere is still attached to it.
Blender does not go further away than changes made by user.
Hi,
I'm not expecting other_lib.blend to be removed but the second Suzanne (from lib_v01.blend) to be linked to lib_v02.blend. And this is not happening. After save reopen, for blender, the second Suzanne is linked to other_lib.blend (but Suzanne has never be part of it).
Did you try the steps to reproduce this bug ?
Sorry. I did not follow correct order.
So, instances are removed on name basis but links are remapped according to their creation order.
Hi,
The issue is here since blender 2.76a I think.
2.75a does not have it.
Added subscriber: @mont29
Well, at least library relocation (rightclick on a lib in outliner, Relocate) does work correctly it seems.
Will see whether we can fix the issue with mere lib renaming, but I doubt this was ever supported, setting same paths for two different lib objects is really, really pulling Blender to its limits…
Ok Bastien,
Can I call the relocate operator from a python file ? I can't see any parameters with it. Or maybe bpy.ops.wm.lib_relocate can do the job ?
Yes, outside of outliner you should use
directly (outliner version is a mere wrapper around that one anyway).Added subscriber: @Sergey
Ok found the core of the issue.
@Sergey I would not be surprised if this was also the cause of the mysterious problems with disappearing libs at the studio.
Have a partial fix, but now we get multiple copies of same linked datablock (like, two copies of Suzanne group from lib_v02 in this report's demo), which is not a good thing either. Still investigating how to fix that second half of the issue…
Hi,
I've tried to use the
but I've got an issue with proxy relinking (I know you're in love with proxies Bastien :) ).I've also tried with the
bpy.ops.outliner.relocate
in the outliner through the interface and the same error appears.Result : the armature proxy become an empty.
Is this a known bug ? If not, I'll try to do a bug report. I have a simple case to reproduce it.
Yep, would appreciate a report about this, relocate should work (but indeed most likely not all corner cases with ugly proxies are ironed out yet :( ).
@mont29 Apparently, the "relocate bug" is not in the 2.79 release but in the 2.78a.
Should I report it nonetheless ?
@g-lul Nope, in fact if a bug does not affect current master, there’s no point in reporting it, since it has already (presumably) been solved. :)
