Python Version in Blender 2.79 and 2.79a #54355
Reference: blender/blender#54355
Why is the Python version of Blender 2.79 higher than the Python version in 2.79a.
Blender 2.79a will not work on a Windows10 system with Python 3.6.4.
The Python Version of Blender 2.79a is 3.5x
I have to delete the path to my Python 3.6.4 to make Blender work.
With the older Blender 2.79 the Python version is 3.6.2 and it works without any
problem on my Win10 and Python 3.6.4.
Why is the Python version downgraded from Blender 2.79 to 2.79a?
Added subscriber: @JD-13
Added subscriber: @LazyDodo
both 2.79 and 2.79a shipped with the same python verison nothing changed on our side
something else must be causing issues for you, what is the exact error your are having?
edit: You are most likely comparing a build from the buildbot which does have a higher python version, however the official released versions have always been on 3.5.3.
@LazyDodo
Hi,
please check the python folders in the 2 versions!
2.79 : Folder \2.79\python\bin there are a python.exe and a python36.dll
2.79a : Folder \2.79\python\bin there are a python.exe, a python 35.dll and a python36.dll
Thus, blender 2.79a will open cmd window when started and terminate it again. Blender will not start. Only if on_system python is disabled it will start and python version is 3.5.3!
Even that there is a python35.dll in the python\bin folder, doesn't seem to sow identical python versions. I am using the windows 64 bit version, and after update from 2.79 to 2.79a even compared now the 2.79win64_vic14 version to 2.79, same result.
with regards,
jd breuer
Added subscriber: @dr.sybren
@JD-13 where did you get the files for 2.79b? If you're basing this on the daily builds, then you're not looking at what will become 2.79b. The daily builds are based on the master branch, which indeed has moved to Python 3.6. However, 2.79b will be a different build, and include the changes listed in #54255.
we are talking of 2.79a and it is from blender.org
The build you have with python 3.6 MUST be a daily build from http://builder.blender.org since both 2.79 and 2.79a shipped with python 3.5.3, (as will the soon to be released 2.79b) no downgrades have taken place. master (while keeping the 2.79 version number, which is indeed a tad confusing) and 2.8 have moved forward while the 2.79 branch didn't. you can validate the build you have as genuine by looking at the build hash , run blender -v and it should display the build hash, this is
5bd8ac9
for 2.79 and8928d99270
for 2.79a . if your build says anything else, please post the hash.I can't reproduce your issue I installed 64 bit python 3.6.4 from the python site, it's in my path and blender runs fine, i'm not doubting you have an issue, but if i can't reproduce it, i can't fix any problems.....
yes, I installed a 2.79_v14 version because I deleted the old 2.79 version I used to have.
the old 2.79 version was nicely working until I installed the 2.79a version. Only if I disable my installed python 3.6.4, the 2.79a with the correct hash will start.
here is the built I installed to be able to continue working:
C:\Program Files\Blender Foundation\Blender>blender -v
Blender 2.79 (sub 3)
Yeah the version you have is NOT 2.79 that is a master build, this will have many new features (and possibly problems) that'll never make it into the official 2.79 build, it's not recommended to use these builds for any production work.
can you run a trace with procmon while starting blender 2.79a and post the trace here? (please filter for just the blender.exe entries)
also please validate that python35.dll is in the same folder as blender.exe
you can also try the .zip version of 2.79a and unpacking it somewhere to see if that helps
Logfile.PML
Yep, I just use 2.79 as I do not like to always rename my Python folder only to start Blender 2.79a.
It just started when I started to use python 3.64 and installed blender 2.79a.
When I start blender in the the cmd window with blender -d, there is the following failure message:
When I rename my c:\Python364 folder in c:\oldPython364, blender 279a starts and works fine
that log file is a little too filtered, just filter all of blender.exe not just the bits you think are relevant.
Hahah, was not sure I was doing it right..... here we go:
Logfile.PML
HI, LazyDodo!
I fond now the solution to the problem.
When Python is being installed for only one user, it sets the PYTHONPATH variable in the user environment variable.
In Win 10 one has to go to useraccount settings and there to set environmental variables for this user by
That did the trick, blender 279a works fine now!
Thanks for your patience with me, hope this will help some other users.
Regards,
didi, Philippines
Thanks for reporting back, I'm still trying to reproduce the issue so i can see if we can do something to make things easier for people running into this in the future.
the python installer doesn't seem to allow me to install for just one user, the option to install for all users is selected and grayed out so i can't change it, i tried manually setting PYTHONPATH but i guess i picked a wrong path cause i still didn't have your issue, do you remember what this variable was set to?
I can imagine that this is caused by the Win10 Version, in my case it is the home edition.
When I installed it for all users, I ran into problems with the user rights and could not make it run at all.
After installing Python for only me, python 3.6x win installer msi, I could select either for all users or just me in manual mode.
As I forgot about this, when I wanted to change the env variable, I was always forced to do this with Admin rights, thus never seeing the path variable for myself.....
Only after browsing some time and learning that several people had this problem, I recognized that there was a difference between the easy accessible system env variables and the user env variable. (but even in cmd with path command, I did not see the PYTHONPATH variable)
Only after knowing how to edit the user env variables, I saw the PYTHONPATH, set to C:\Python364
Hope this helps a little!
Greetings, Didi
Added subscriber: @lichtwerk
Skimming over this I assume this is resolved and can be closed then?
