"Add simple UVs" unwrap different in Blender 2.79 from master #54410
5 Participants
Reference: blender/blender#54410
Kubuntu Linux 64bits
Broken: From buildbot, master
aeec19d2e7
Worked: 2.79a
"Add simple UVs" unwrap different in Blender 2.79 from master, at least in default cube. Unwrapped cube results with overlapping faces, which causes problems when painting. I'm not sure if this is due to some intentional code change, or a bug.
Thanks to jensverwiebe for test this in IRC channel.
Add Cube without UVs. Select cube and go to Texture Paint mode. In Tool Shelf panel, in Tools tab press "Add simple UVs" button. Now see the result in UV / Image editor. Compare with 2.79 official releases, where it works well.
Added subscriber: @YAFU
Added subscriber: @LazyDodo
I'm pretty sure it's this commit.
759b50b20b
Added subscriber: @lichtwerk
Confirming it's caused by above mentioned commit. @ideasman42: feel free to assign to me and I'll try my luck :)
This was fixed in
ba94aaedba
Added subscriber: @zeauro
It looks like problem was not properly fixed in no release since 2.79.
The goal of "Add Simple UVs" button was to generate UVs to paint meshes created by Dyntopo, at a time, when it was deleting UVmap.
Now, problem is unnoticed. Because UVs generation is automatic, And Dyntopo tries to preserve an existing UV map.
So, "Add Simple UVs" button is almost never displayed. But problem is still present.
Currently, "Add Simple UVs" unwraps any mesh with a failed Projection. The result is UVfaces that are overlapping.
Add a Sphere or a Torus.
Disable Generated UVs in redo panel.
Go to Texture Paint Workspace.
Press Add Simple UVs button.
Go to UV Editing Workspace.
Menu UV > Seams from UV Islands.
Some seams are missing to obtain a correct Cube Projection, made of 6 Islands. Only 4 have been created.
As a result, 2 of them have overlapping UV Faces.
Here is a .blend file showing the problem with current UVs from Add Simple UVs.
In attached file, just paint a stroke. Then, rotate 3D view to see the other side of mesh.
Add_Simple_UVs_Issue.blend
