Data Transfer modifier's Max Distance field working strangely #54526
6 Participants
Reference: blender/blender#54526
Using Blender 2.89b. EVGA GTX1070. Win10. All non-default add-ons disabled and new scene loaded.
Attached demonstration file contains a cube using a data transfer with max distance enabled to copy weights from a nearby plane, and an armature for that cube. Max Distance settings should put four verts in the domain of the modifier; as you can see, seven verts are affected.
Problem encountered in less abstract situations as well, this is just my simplest reduction of the problem in order to verify that it's an issue and make it plain to see and reproduce.
For reference, official documentation reads, "This allows to transfer a small sub-detailed mesh onto a more complete one (e.g. from a “hand” mesh towards a “full body” one)," which would be useful if it were working properly.
DataDistance1.blend
Added subscriber: @vasiln
Added subscriber: @lichtwerk
Confirming on first sight, having a closer look now...
Added subscriber: @mont29
I'll claim for the time being and do some further investiagtion. If that doesnt succeed, I'll get @mont29 on board to help me out...
Coming back to add that there's a reasonable workaround, which is to use a vertex weight proximity modifier to determine the distance from each vertex before the weight transfer, use a custom (constant) curve to modulate that vertex group, and then use it to modulate the data transfer. It's a bit more work for the end user, but perfectly reasonable, and it wouldn't seem unreasonable to just drop support for max distance from the data transfer.
Added subscriber: @angavrilov
Had a look at this again and here are some findings:
BKE_mesh_remap_calc_verts_from_mesh
/mesh_remap_bvhtree_query_nearest
is where things happennearest.index
to -1]BLI_bvhtree_find_nearest()
is called with a "nearest" provided, code will not update anything on "nearest" (esp. notindex
, notdist_sq
) if it fails to find something.index
is not neccessarily -1 if it fails to find something.nearest.index
non-zero], and then for the next vertex dont find anything, we still have a non-zeroindex
leading to false positives in the following code.It actually works fine if the index is reset to -1 for each vert.
Could be like this (would have to be done for a couple of other loops as well):
P967: T54526_snippet_1
Or more general like:
P968: T54526_snippet_2
@angavrilov, @mont29: what do you think?
@lichtwerk nice catch. Wouldn’t it be even simpler to always reset that
nearest->index
directly inBLI_bvhtree_find_nearest_ex()
? Keeping previous nearest distance there if provided makes sense, but I think item index should be always reset, at least I cannot see a case where keeping previous value would be useful?Added subscribers: @mano-wii, @brecht
I went over usages of
/BLI_bvhtree_find_nearest_projected
and here are some findings:these are the ones that always set item index to -1 before calling, it looks like an index of -1 ALWAYS should be OK:
dynamic_paint_paint_mesh_cell_point_cb_ex
(called in a loop, item index set to -1 prior every time)BKE_bmbvh_find_vert_closest
(called once, item index set to -1 prior)BKE_bmbvh_find_face_closest
(called once, item index set to -1 prior)closest_point_on_surface
(called once, item index set to -1 prior)obstacles_from_mesh_task_cb
(smoke code, called in a loop, item index set to -1 prior every time)sample_mesh
(smoke code, called once, item index set to -1 prior)remap_hair_emitter
(called in a loop, item index set to -1 prior every time)rna_Object_closest_point_on_mesh
(called once, item index set to -1 prior)nearestVert
(surface deform modifier, called once, item index set to -1 prior)vert2geom_task_cb_ex
(weight proximity modifier, called once, item index set to -1 prior every time)py_bvhtree_find_nearest
(called once, item index set to -1 prior)find_nearest_points_test
(called with NULL)snapping: these are the ones that set item index to -1 before calling but then could enter multiple times (vert, edge, ...), not sure if an index of -1 ALWAYS would be OK? maybe @mano-wii knows more?:
snapMesh
(item index set to -1 prior, but multiple usages here which could all be entered?... not sure)snapEditMesh
(item index set to -1 prior, but multiple usages here which could all be entered?... not sure)shrinkwrap: not 100% sure, but it looks like an index of -1 ALWAYS should be OK
shrinkwrap_calc_nearest_vertex_cb_ex
(resets index to -1, but in ParallelRangeSettings, seeshrinkwrap_calc_nearest_surface_point
, not 100% sure...)BKE_shrinkwrap_find_nearest_surface
(does not reset index to -1, needs checking, called fromshrinkwrap_get_tarmat
[where index is set to -1] /shrinkwrap_calc_nearest_vertex_cb_ex
[see above])our candidate for this report:), looks like an index of -1 ALWAYS should be OK
(does not reset index to -1 atm., results in bug)Will also subscribe @brecht as lead architect here, but if we want to have this in for RC1, propose to actually play safe and go with D5206?
Keeping the previous search result when doing multiple nearest searches is a very important heuristic optimization. Not doing that in shrinkwrap for instance will absolutely butcher performance.
This heuristic however obviously relies on the previous search result being a valid candidate for the new search (i.e. it can be reused as is if it's still the nearest point).
More specifically, BVH nearest search code by default doesn't bother to ensure an optimal search order through the tree, because using the previous search result to prime the search and prune the tree works out to be faster. When implementing the new more complicated shrinkwrap mode that can't use this heuristic, I had to add
andBVH_NEAREST_OPTIMAL_ORDER
to get good performance.Perhaps
should be the default behavior instead (and also ignore the previous result), while the heuristic behavior should be invoked throughBVH_NEAREST_REUSE_RESULT
or something like that. I did it the way it is currently to avoid changing old code all over the place.@angavrilov : thx for the heads up, will check on this (might take a bit to go over all cases), for the "quick fix": D5206 should still be fine, right?
These are cases where changing the nearest.index to -1 between calls would result in problems.
Still an issue. Will have to go through the points raised here (and in D5206) again
This issue was referenced by
3b84dce969
