can't export to .fbx with UV map #54684
Closed
opened 2018-04-17 07:44:05 +02:00 by toast · 6 comments
windows 10, intel integrated hd graphics 530
Broken: 2.79b
try to export to .fbx
heck.blend
**System Information** Operating system and graphics card windows 10, intel integrated hd graphics 530 **Blender Version** Broken: 2.79b Worked: (optional) **Short description of error** can't export to .fbx with UV map **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps try to export to .fbx [heck.blend](https://archive.blender.org/developer/F2755768/heck.blend)
Author
Added subscriber: @ToastyEngineer
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2018-04-17 10:16:20 +02:00
Member
Confirmed, having a closer look now...
Member
You have a couple of UVs with undefined positions (NANs) in "UVMap" ("UV1" doesnt have these and exports fine)
Can be checked with this script:
import bpy
import math
uvlayer = bpy.context.active_object.data.uv_layers['UVMap']
for x in range(len(uvlayer.data)-1):
    if math.isnan(uvlayer.data[x].uv[0]):
        print("index for nan: ", x, uvlayer.data[x].uv)
should give you following output:
index for nan:  73600 <Vector (-nan, -nan)>
index for nan:  73602 <Vector (-nan, -nan)>
index for nan:  73606 <Vector (-nan, -nan)>
index for nan:  73609 <Vector (-nan, -nan)>
index for nan:  73612 <Vector (-nan, -nan)>
index for nan:  73615 <Vector (-nan, -nan)>
index for nan:  73618 <Vector (-nan, -nan)>
index for nan:  73620 <Vector (-nan, -nan)>
index for nan:  73623 <Vector (-nan, -nan)>
index for nan:  73627 <Vector (-nan, -nan)>
index for nan:  73630 <Vector (-nan, -nan)>
index for nan:  73633 <Vector (-nan, -nan)>
index for nan:  73636 <Vector (-nan, -nan)>
index for nan:  73639 <Vector (-nan, -nan)>
index for nan:  73641 <Vector (-nan, -nan)>
index for nan:  73644 <Vector (-nan, -nan)>
index for nan:  73647 <Vector (-nan, -nan)>
index for nan:  73651 <Vector (-nan, -nan)>
index for nan:  73654 <Vector (-nan, -nan)>
index for nan:  73656 <Vector (-nan, -nan)>
index for nan:  73659 <Vector (-nan, -nan)>
index for nan:  73662 <Vector (-nan, -nan)>
index for nan:  73665 <Vector (-nan, -nan)>
index for nan:  73668 <Vector (-nan, -nan)>
Question is where these come from in the first place, because these can cause problems with all kinds of tools.
Was this unwrapped in blender? Or imported with one of the official addons?
(I wasnt able to produce NAN UVs with blenders unwrapping methods, so if you use these, you should be fine and able to export)
Like I said, I dont think it is even desirable to let the FBX exporter check for these NAN (would make it slower) and time is better spent investigating where these NANs come from (to also prevent other tools having trouble with them)
note: I havent spent time investigating if there is a quick method to do a cleanup on these UVs (get rid of the NANs)
Marking as incomplete until we get an answer on how these UVs were generated...
You have a couple of UVs with undefined positions (NANs) in "UVMap" ("UV1" doesnt have these and exports fine) Can be checked with this script: ``` import bpy import math uvlayer = bpy.context.active_object.data.uv_layers['UVMap'] for x in range(len(uvlayer.data)-1): if math.isnan(uvlayer.data[x].uv[0]): print("index for nan: ", x, uvlayer.data[x].uv) ``` should give you following output: ``` index for nan: 73600 <Vector (-nan, -nan)> index for nan: 73602 <Vector (-nan, -nan)> index for nan: 73606 <Vector (-nan, -nan)> index for nan: 73609 <Vector (-nan, -nan)> index for nan: 73612 <Vector (-nan, -nan)> index for nan: 73615 <Vector (-nan, -nan)> index for nan: 73618 <Vector (-nan, -nan)> index for nan: 73620 <Vector (-nan, -nan)> index for nan: 73623 <Vector (-nan, -nan)> index for nan: 73627 <Vector (-nan, -nan)> index for nan: 73630 <Vector (-nan, -nan)> index for nan: 73633 <Vector (-nan, -nan)> index for nan: 73636 <Vector (-nan, -nan)> index for nan: 73639 <Vector (-nan, -nan)> index for nan: 73641 <Vector (-nan, -nan)> index for nan: 73644 <Vector (-nan, -nan)> index for nan: 73647 <Vector (-nan, -nan)> index for nan: 73651 <Vector (-nan, -nan)> index for nan: 73654 <Vector (-nan, -nan)> index for nan: 73656 <Vector (-nan, -nan)> index for nan: 73659 <Vector (-nan, -nan)> index for nan: 73662 <Vector (-nan, -nan)> index for nan: 73665 <Vector (-nan, -nan)> index for nan: 73668 <Vector (-nan, -nan)> ``` Question is where these come from in the first place, because these can cause problems with all kinds of tools. Was this unwrapped in blender? Or imported with one of the official addons? (I wasnt able to produce NAN UVs with blenders unwrapping methods, so if you use these, you should be fine and able to export) Like I said, I dont think it is even desirable to let the FBX exporter check for these NAN (would make it slower) and time is better spent investigating where these NANs come from (to also prevent other tools having trouble with them) note: I havent spent time investigating if there is a quick method to do a cleanup on these UVs (get rid of the NANs) Marking as incomplete until we get an answer on how these UVs were generated...
Member
Member
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
2 Participants
Reference: blender/blender-addons#54684
