Massive slowdown when animating material in a highpoly mesh #55326
6 Participants
Reference: blender/blender#55326
Broken:
bda0175984
(blender2.8 HEAD)Short description of error
If you keyframe any material nodetree node input the playback performance suffers severely
wasp_bot.blend
from EEVEE sample files.HEAD
object with a simple emission node.Test playback performance in your system. - It should be fast.
Re-evaluate playback performance - It should be slow.
Note, performance goes back to normal in the following cases:
Added subscriber: @dfelinto
#62176 was marked as duplicate of this issue
Added subscribers: @brecht, @fclem
Adding @brecht as a subscriber too in case he wants to have fun profiling it.
I found the problem:
Also note that the comment on DRW_mesh_batch_cache_dirty about:
This is not correct. If we update the UV and tangent data every time the shader changes this will be also super slow since tangent is the batch slowest to calculate.
This was introduced on
0a57597aff
by the way.Added subscriber: @Sergey
The problem here is that we are missing a more fine grained tagging of the shader nodetree.
As of now, there is no way to know if the user changed a UV channel name in a UV node or just a value of a socket.
The former needs a batch recreation because the needed CD Layers are not the same anymore.
Adding a simple file to reproduce the issue
shading_update_perf.blend
Just open the file and change emission shader color. It should be has fast as when subdiv level is 0.
It should not call BKE_mesh_batch_cache_dirty(object->data, BKE_MESH_BATCH_DIRTY_SHADING) in this instance. Only modifying Tangent/UV maps nodes (and maybe a few others) should do that.
Please note that
7ad8272952
made it at least twice faster already but does not fix the core of the problem.I noticed the same kind of slowness when editing material nodes on high poly meshes.
Fine grained dependency graph tagging seems difficult here, I think it would require compiling the GPU shader to know exactly which mesh attributes are affected by the change.
Would it be possible to not discard the GPU buffers on BKE_MESH_BATCH_DIRTY_SHADING, but rather on draw compare if the requested attributes still match the previous ones?
Added subscribers: @Rawalanche, @ZedDB
@fclem, we've discussed things here at the studio, and the solution was not related to the dependency graph changes.
Let me know if there is something else i can help you here with.
@Sergey Everything on my end has been fixed.
Only removing the batch cache tagging from the depsgraph is needed to fix this issue. I tried to do it but depsgraph was complaining about some missing link thingamajig.
@fclem, just to verify, mind testing P958: (An Untitled Masterwork)
@Sergey I confirm it fixes the slowdown.
This issue was referenced by
8955ec6776
I've just tested latest build and I can confirm it also fixes the #62176
