Mesh from Curve not working on curves beveled by curves #56906
11 Participants
Reference: blender/blender#56906
Windows 10 Pro - version 1803 - build 17134.285
Intel Core i5-3350p
Nvidia GeForce GTX 780
RAM DDR3 2x4GB 1333mhz running dual channel
Broken: 2.8 (Downloaded 21. 09. 2018)
Worked: 2.79
Object Mode > Object > Transform > Mesh from Curve\Meta\Surf\Text
When applied to a curve directly beveled by shape of another curve, it does not create a mesh, only turns the original curve into edges.
RESULT IN 2.79b: Turns the curve into a torus-shaped mesh.
Added subscriber: @dligac
#58057 was marked as duplicate of this issue
#57676 was marked as duplicate of this issue
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Added subscriber: @zeauro
I can reproduce. There is no crash.
Beveled_Circle.blend
I don't think we can consider beveled curves as a restored feature, yet.
You propose to change Bevel Start value to force update of display of torus. But if start value is up to zero, torus should not be displayed as a complete torus.
I missed the "don't post bugs for 2.8 unless crashing" rule. So it shouldn't be here.
However I don't know what are you talking about anyway. I have trouble turning curve into a mesh. That's the reason I posted it here. So I don't propose anyting regarding bevel start value and blah blah, I propose that curve to mesh works just like in 2.79. Get it?
I got it. I was just explaining that mesh from curve is not the only thing about curve that does not work as it should. Beveled Curves are not supposed to behave like that.
And several other things don't work as they should for other types of objects than meshes.
It will be fixed when a developer will take time to review curves. But for the moment, most of work done was focusing on meshes, armatures and new grease pencil objects.
Added subscriber: @Marco-Neumann
Added subscribers: @szymi, @ChristopherAnderssarian, @lichtwerk
May i ask the developers to fix curve conversion to mesh,i uploaded this request before,please dear developers,i cannot use bevel curve with profile shape,because after conversion,only edges are left,i need this feature back to work,because i cannot sweep a window frame or any shape,this feature is hugely important for me,without it,i am unable to create advanced,lofted shape,nurbs surface also are not visible in the viewport in Blender 2.80 - build from 22.11.2018
Added subscriber: @Enside
This issue was referenced by
98ecab1af0
Blender Developpers - THANK YOU FOR BIG EFFORT - now i can convert curve to mesh!
{F5760850}thank you - conversion to mesh from curve works - thank you - i am appreciate of your work{F5760908}
Added subscriber: @Hickz
This is broken again
Added subscriber: @Varlam
Confirm. broken again. Today build 24.05.
There is not much point in re-activating closed tasks like that, it is fairly unlikely to be the same issue actually( even though the symptoms are the same, code has changed quiet a bit since then).
FYI, we already have a (new) task about that issue: #65052
Added subscriber: @bugsbe
Just chiming making flat objects then making them 3dish in blender 2.8 is a huge mess.
And can someone please do something about the headache inducing grey on grey?
Added subscriber: @Anthony-Attwood
Just here to repoer that it still doesn't work but a work-around is to select the beveled curves, export selection as obj then import the obj.
