Python: "drivers_remove" not working and crashing with invalid drivers #58964
6 Participants
Reference: blender/blender#58964
Win 10
Gtx 980
The drivers_remove function is broken when removing invalid drivers.
driver_deletion.blend
A workaround I did in Blender 2.79 was changing the driver data_path to a valid one before deleting. It now crashes in 2.8:
Added subscriber: @LucasVeber
Added subscriber: @ZedDB
I can reproduce this issue, this is the backtrace I get:
(I'm guessing this is depsgraph related)
Added subscribers: @ideasman42, @Sergey
@ideasman42 , i've fixed the crash issue, but is still annoying that
driver_remove
can't be used for an invalid driver. This is caused by some validation happening inpyrna_struct_anim_args_parse()
which i am not sure why we need that at all. I think is reasonable to use path and index passed to the function?P.S. Even if the
driver_remove()
is solved for the invalid drivers, the original script will still crash because it removes drivers from a list during traversal of that list.Added subscriber: @mont29
Well,
is also used to build a valid, normalized RNA path from given path & index, so think using it here first is OK. Though we should probably not error if it fails, but instead just build a dummy unchecked path out of path/index pair, and try to remove that one?@mont29, but this is like saying that
rm
utility will first normalize and such path you give to it before attempting to remove it. Not sure i'd trust such a removal utility =/In this case it's best to directly remove the drivers, committed API calls to create/remove drivers directly.
abe32d2a35
Now you can call
obj.animation_data.drivers.remove(some_driver)
.Even so,
driver_remove()
should be able to support drivers which have data-paths that no-longer resolve.There is a chance that this will fail (if the string isn't an exact match for eg), a collection could be referenced by string or by index, but think this isn't all that likely.
So we could make keyframe & driver removal fall-back to doing a string match.
This issue was referenced by
07287ceda1
