Keyframed node properties stay linked after shading network duplication #59062
Reference: blender/blender#59062
Operating system: windows 10
Graphics card: gtx 760
Broken: 2.8 beta
Worked: 2.79
If I duplicate from the properties panel a shader that as animated nodes, those animated nodes are linked in some way by their keyframes : if I move or delete a keyframe on the base shader, it moves or delete it also on the duplicated shader, althought I can change node properties that are not keyed. You'll find a test file showing the bug, the animation is on the color mix node. Just move or delete a keyframe on the animation.
animated_nodes_bug.blend
Added subscriber: @boustalahit
#62393 was marked as duplicate of this issue
Added subscribers: @JacquesLucke, @JoshuaLeung, @lichtwerk
Confirmed.
Seems another issue with data path resolution on nodes [I dont remember the details, but I do recall there were issues relating to this (nodes and drivers e.g.)]
Also note that renaming a node will break the animation actually (was not the case in 2.79)
#59256 is related
@JoshuaLeung: mind sharing your wisdom?
or maybe @JacquesLucke has an idea?
Added subscriber: @Sergey
#59390 was also reported (which I think has the same roots)
adding @Sergey here...
Interstingly, though #59390 is resolved, this is still happening.
So making a single material user from the
row.template_ID(ob, "active_material", new="material.new")
doesnt seem to do the same thing asObject
>Relations
>Make Single User
>Materials
Added subscriber: @mont29
@mont29: can you confirm the above? (difference between
Object
>Relations
>Make Single User
>Materials
and using the template_ID from the Properties Editor [doesnt matter if you make single user or add new from there])Properties Editor doesnt seem to make animation unique, whereas
Object
>Relations
>Make Single User
>Materials
seems to do so...Should this be consistent (just asking...)?
Those are two different operators/operatioons, but do not see why copying material from IDTemplate widget should not also duplicate its actions. Fix incoming.
This issue was referenced by
a75ac18638
Changed status from 'Resolved' to: 'Open'
Looks like this popped up again (#62393).
@mont29: I can confirm that making a new material from the template IDTemplate widget duplicates the action, whereas making it a single user still doesnt.
Added subscriber: @VladimirKunyansky
Hm,
BKE_animdata_from_id()
returns NULL inBKE_animdata_copy_id_action()
when doing this?Gotta go now, but will have another look later...
Please do not merge just because issues are similar, those remain two different things.
So we have
id_single_user()
vs.single_mat_users()
id_single_user()
doesnt traverse down the nodetree and doesnt copy nodetrees action, whereassingle_mat_users()
does.Same thing is happening in 2.79
I am not exactly sure if we would always want the behavior of copying actions here, but if in doubt, my vote would go for it, patch incoming...
@mont29: oki, posted patch for #62393 then...
