Blender 2.8 particle system error #59924
Closed
opened 2018-12-28 12:51:44 +01:00 by garyshin · 11 comments
Operating system: win8.1 64bit
Graphics card: gtx 1060 4GB
Broken: blender-2.80-0661bcba3210-win64
28, Dec, 18
when running keyed particle system, if the base object has complicated(?)mesh or rather say a lot of vertices, emitted object will not move as it supposed
to be.particle_error.blend
I found that the when I change the base object to simple geometry, it works anyway. But it has still weird glitches when animated scene.
(ex: particle placed in totally random position)
**System Information** Operating system: win8.1 64bit Graphics card: gtx 1060 4GB **Blender Version** Broken: blender-2.80-0661bcba3210-win64 28, Dec, 18 Worked: (optional) **Short description of error** when running keyed particle system, if the base object has complicated(?)mesh or rather say a lot of vertices, emitted object will not move as it supposed to be.[particle_error.blend](https://archive.blender.org/developer/F6096165/particle_error.blend) I found that the when I change the base object to simple geometry, it works anyway. But it has still weird glitches when animated scene. (ex: particle placed in totally random position) **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @garyshin
Member
Added subscriber: @lichtwerk
Member
Could you try to explain in more depth what you mean by "object will not move as it supposed"
I can happily add a particlesystem to complex_terrain object (with the same particlesettings as on the simpleplane object), change the second psys in Keys on the simpleplane and get somewhat expected movement?
Marking as incomplete until we have further information...
Could you try to explain in more depth what you mean by "object will not move as it supposed" I can happily add a particlesystem to `complex_terrain` object (with the same particlesettings as on the `simpleplane` object), change the second psys in Keys on the `simpleplane` and get somewhat expected movement? Marking as incomplete until we have further information...
Author
on a viewport both plane (complex_terrain, simpleplane) works well.
but when complex_terrain is the base for an animation, there's nothing on the rendered image.
(keyed particle objects are supposed to move toward the complex_terrain)
I rendered it as an animation (render animation) and set the file format to .png
on a viewport both plane (complex_terrain, simpleplane) works well. but when complex_terrain is the base for an animation, there's nothing on the rendered image. (keyed particle objects are supposed to move toward the complex_terrain) I rendered it as an animation (render animation) and set the file format to .png
Member
Member
Can you still reproduce the issue in the newest Blender version?
I'm still not sure how to reproduce the bug. Please make a short screen recording that shows the issue.
Can you still reproduce the issue in the newest Blender version? I'm still not sure how to reproduce the bug. Please make a short screen recording that shows the issue.
Author
2019_01_23_09_40_13.avi
2019_01_23_09_32_11.avi
rendered with 2.79 version : 2019_01_23_09_40_13.avi
rendered with 2.8 build (blender-2.80.0-git.dd3f5186260e-windows64) : 2019_01_23_09_32_11.avi
Hope you understand through this video.
[2019_01_23_09_40_13.avi](https://archive.blender.org/developer/F6373150/2019_01_23_09_40_13.avi) [2019_01_23_09_32_11.avi](https://archive.blender.org/developer/F6373145/2019_01_23_09_32_11.avi) rendered with 2.79 version : 2019_01_23_09_40_13.avi rendered with 2.8 build (blender-2.80.0-git.dd3f5186260e-windows64) : 2019_01_23_09_32_11.avi Hope you understand through this video.
Added subscribers: @brecht, @ZedDB
I can confirm that when I change the settings so that the cubes should travel to the terrain, it shows up correctly in viewport, but the particles are all stuck to the emitter plane when I try to render.
@brecht who to assign this to (if any)?
I can confirm that when I change the settings so that the cubes should travel to the terrain, it shows up correctly in viewport, but the particles are all stuck to the emitter plane when I try to render. @brecht who to assign this to (if any)?
Sergey Sharybin was assigned by Sebastian Parborg 2019-01-28 10:13:10 +01:00
This issue was referenced by 8683a4ba40
This issue was referenced by 8683a4ba40831e1436edc889299f062659af6712
6 Participants
Reference: blender/blender#59924
