Backtrace when importing FBX file from the Unity asset store #62984
Closed
opened 2019-03-26 20:48:11 +01:00 by Pete Chown · 6 comments
Operating system: Linux-4.15.0-46-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 415.27
Broken: version: 2.80 (sub 51), branch: blender2.7, commit date: 2019-03-25 23:15, hash: adfdae3fc2
Backtrace when importing some FBX files.
Unfortunately providing exact reproduction steps is difficult because the FBX file is not mine to distribute; it's from the Unity asset store. However I have a fix and I think it makes sense bearing in mind the surrounding code. First of all, this is the backtrace:
  File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/__init__.py", line 231, in execute
    return import_fbx.load(self, context, **keywords)
  File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 2889, in load
    _(); del _
  File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 2887, in _
    blen_read_animations(fbx_tmpl_astack, fbx_tmpl_alayer, stacks, scene, settings.anim_offset)
  File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 720, in blen_read_animations
    if id_data.type == 'MESH' and id_data.parent and id_data.parent.type == 'ARMATURE':
AttributeError: 'NoneType' object has no attribute 'type'
That section of code looks like this (from 2.80/scripts/addons/io_scene_fbx/import_fbx.py):
                if isinstance(item, Material):
                    id_data = item
                elif isinstance(item, ShapeKey):
                    id_data = item.id_data
                elif isinstance(item, Camera):
                    id_data = item
                else:
                    id_data = item.bl_obj
                    - XXX Ignore rigged mesh animations - those are a nightmare to handle, see note about it in
                    - FbxImportHelperNode class definition.
                        continue
                if id_data is None:
                    continue
The exception is thrown on the id_data.type == 'MESH' line and it happens because id_data is None. The next statement tests for this condition and if it holds, executes continue. It seems reasonable then to change the line to read:
                    if id_data is not None and id_data.type == 'MESH' and id_data.parent and id_data.parent.type == 'ARMATURE':
What do you think? This fix seems to allow correct imports of the FBX file concerned on my system.
**System Information** Operating system: Linux-4.15.0-46-generic-x86_64-with-debian-buster-sid 64 Bits Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 415.27 **Blender Version** Broken: version: 2.80 (sub 51), branch: blender2.7, commit date: 2019-03-25 23:15, hash: `adfdae3fc2` Worked: (optional) **Short description of error** Backtrace when importing some FBX files. **Exact steps for others to reproduce the error** Unfortunately providing exact reproduction steps is difficult because the FBX file is not mine to distribute; it's from the Unity asset store. However I have a fix and I think it makes sense bearing in mind the surrounding code. First of all, this is the backtrace: ``` Traceback (most recent call last): File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/__init__.py", line 231, in execute return import_fbx.load(self, context, **keywords) File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 2889, in load _(); del _ File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 2887, in _ blen_read_animations(fbx_tmpl_astack, fbx_tmpl_alayer, stacks, scene, settings.anim_offset) File "/nobackup/src/blender-2.80-adfdae3fc2f4-linux-glibc224-x86_64/2.80/scripts/addons/io_scene_fbx/import_fbx.py", line 720, in blen_read_animations if id_data.type == 'MESH' and id_data.parent and id_data.parent.type == 'ARMATURE': AttributeError: 'NoneType' object has no attribute 'type' ``` That section of code looks like this (from 2.80/scripts/addons/io_scene_fbx/import_fbx.py): ``` if isinstance(item, Material): id_data = item elif isinstance(item, ShapeKey): id_data = item.id_data elif isinstance(item, Camera): id_data = item else: id_data = item.bl_obj - XXX Ignore rigged mesh animations - those are a nightmare to handle, see note about it in - FbxImportHelperNode class definition. if id_data.type == 'MESH' and id_data.parent and id_data.parent.type == 'ARMATURE': continue if id_data is None: continue ``` The exception is thrown on the `id_data.type == 'MESH'` line and it happens because `id_data` is `None`. The next statement tests for this condition and if it holds, executes `continue`. It seems reasonable then to change the line to read: ``` if id_data is not None and id_data.type == 'MESH' and id_data.parent and id_data.parent.type == 'ARMATURE': ``` What do you think? This fix seems to allow correct imports of the FBX file concerned on my system.
Author
Added subscriber: @PeteX-2
Added subscriber: @mont29
Bastien Montagne self-assigned this 2019-03-27 08:51:11 +01:00
Indeed seems to make sense, thanks for the investigation and patch, will commit.
This issue was referenced by blender/blender-addons@ad2ee4cd6f
This issue was referenced by blender/blender-addons@ad2ee4cd6f97d2bfbe6a77e76baa5ad4de8e4b34
This issue was referenced by blender/blender-addons@d0aa840bff
This issue was referenced by blender/blender-addons@d0aa840bff2c7007d7f8595fa5f0475f9872e3f0
Reference: blender/blender#62984
