Wrong rotation input values when using shortcuts on keyboard like rx720 #67067
5 Participants
Reference: blender/blender#67067
Operating system: Windows 10
Graphics card: GTX 1080 Ti
Broken: 2.80 Release Candidate 1
Rotation values inputted after hitting "r" and then hitting an axis value like "x" are wrong.
If I select an Object and hit "r" then "x" then "720" then "return", the X-rotation will be set to 0.00002d
Or if i enter rx359 the x-rotation will be set to -1.
If I input them in the n-panel it works fine, if I input them in the properties panel it works fine, too. And if I use the widget to rotate the cube two times in that axis and let go it's also 720 degrees. The wrong values appear just when inputting them the way described above.
I think this should be consistent all over the place and it really makes no sense that it rotates my cube -1 on the x-axis when i clearly wanted it to rotate 359 degrees in the other direction on that axis...
Select an Object and hit "r" then "x" then "720" then "return", the X-rotatioin will be set to 0.00002d
Or enter rx359 the x-rotation will be set to -1.
Added subscriber: @JohannesWunsch
Added subscribers: @WilliamReynish, @brecht, @ZedDB
@WilliamReynish @brecht Thoughts on this matter?
This would be good to improve but it's not considered a bug currently.
The rotation value entered here goes through various transforms and representations which can't preserve the difference between 0 and 360. We could add a special code path for the simple case where the entered value equals the Euler value on the object, but that's outside the scope of this tracker.
Added subscriber: @mont29
Hmmm… this is actually a sequel of #48998, looks like I fixed clamping of the drawn value then, but not the actual application of said value.
Applying rotation goes through matrix, which simply does not support rotation outside of the ]-180, 180] range. Thing is, with other transform tools, value gets applied often, so steps between applications are always below 360°. With num input, it gets applied in a single step, where the clamping gets visible.
Trying to find a fix currently (which is proving to be much, much more difficult than anticipated :( ), but would not recommend adding it to 2.80 release in any case, this can have unexpected side effects, and reported behavior have been there since the dark ages of Blender…
eeeh… was triaged in-between…
@brecht imho this is really a bug, and a rather annoying one, though nothing like a regression… This has to be fixed somehow, that’s a nasty usability flow making numinput essentially useless for rotations currently.
This issue was referenced by
cee484a4c5
