Wireframe not updating after applying subsurf #67888
6 Participants
Reference: blender/blender#67888
Graphics card: GeForce GTX 950M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.36
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-26 09:51, hash:
62338abde4
Worked: 2.79 official release
Wireframe doesn't update in viewport after applying subsurf with optimal display enabled.
1: Add suburf modifier to default cube
2: Make viewport setting to like 4
3: Enable wireframe and all edges
4: Enable "Optimal Display" on subsurf modifier
5: Apply modifier
Can enter edit mode and then back to object mode to update wireframe.
Added subscriber: @AFWS
Added subscriber: @MarcinTwarowski
I made a test file:
cube_wireframe.blend
Added subscriber: @dr.sybren
Confirmed on current master (
03f652b2c1
).I tried adding
WM_event_add_notifier(C, NC_GEOM | ND_DATA, ob->data);
andDEG_id_tag_update((ID *)ob->data, ID_RECALC_GEOMETRY);
to themodifier_apply_exec()
function, but that didn't solve it. You can even switch between Rendered/Solid/LookDev/Wireframe, or enable/disable drawing of overlays, and it'll still keep drawing the "Optimal Display" subdivision view.Added subscriber: @Jeroen-Bakker
Changed status from 'Confirmed' to: 'Needs User Info'
@dr.sybren , @AFWS is this still an issue? Or should we close this one.
Yup, still an issue.
Added subscriber: @RyanJEC
Wireframe overlay doesn't apply to Subdiv if added right after mirror modifier either.
You can put Subdiv first to get the Wireframe, but then mirror clipping doesn't work because mirror has to be first.
This may not be related, if not I'll make a new bug task.
The control edges are provided by subsurf modifier and stored in the mesh. During drawing the draw engine still sees and uses the data.
Solution would be to clean up these control data after applying the subsurf modifier so the base mesh doesn't have the data.
This issue was referenced by
7ed3ebbc6e
