VR design / usability #68994
Open
opened 2019-08-21 16:19:48 +02:00 by Dalai Felinto · 13 comments
The following lists a number of higher level, usability related questions that have to be figured out.
General Workflow
How will navigation in the virtual world happen?
Early on, we should decide how navigation in the VR view will work. It should probably be usable with and without handheld controllers.
Other VR engines have already implemented their solutions, which may be useful as a reference.
How can we create workflow specific VR UIs?
It would be nice if VR UIs could be integrated well with other workflow mechanics we have in Blender. For example there could be a simplified UI for 101-like templates, or specialized sculpting UIs. A version with focus on accessibility might also be interesting, VR offers new approaches for handicapped access.
Basically we shouldn’t set one VR UI in stone, but allow people to come up with better or alternative solutions for specified use-cases. We’d still deliver a polished default experience obviously.
This has big technical implications, as it influences how tools, operators, gizmos and other graphical elements have to be implemented.
Operators, Tools & Gizmos
How will operators, tools and gizmos work together in VR?
Will we only provide the active-tool concept, or can we allow non-modal operator execution as well? How will tools and operators be selected/invoked?
How can users customize keymap bindings of controllers?
Note: The OpenXR specification “outsources” this part to the runtime. In Blender we would listen to abstract actions (e.g. “Teleport”) and the OpenXR runtime (Oculus, Windows Mixed Reality, etc.) binds this to a device button/gesture. This makes our job easier, we don’t have to care for device specific keymap bindings.
So assuming we don’t need to listen to device specific button events (which might still be needed), OpenXR already answered this question for us.
Setup
How is the VR reference space defined?
What’s needed is a point in space that acts as the origin of the VR experience, a up direction and an initial direction to look at (always perpendicular to the up direction?).
Note that the up direction and the origin basically define the floor plane.
The OpenXR runtime calculates the head position/rotation based on that, including eye level above the ground. It can also define the room/movement boundaries.
Other engines probably already figured this out and we may be able to copy them.
How can settings be accessed from within the VR session?
There are different settings to think about: Viewport settings, VR-specific settings (e.g. toggle positional tracking), operator settings, tool settings, etc. We’d probably not expose properties editor or user preference settings for now, although we could make it possible to show any editor in a 3D floating popup.
How can users change settings for the VR session, but outside of it? Do we allow this at all?
For example, users may want to change viewport settings from the regular 2D UI, because the VR session renders too slow. This also matters for users that don’t have controllers.
How are session defaults and startup settings defined?
This is mainly about viewport settings (display mode, lighting, shading, etc.) and VR specific settings. You may want to set these up even before the session starts. And you may want to set your own default settings, too.
The following lists a number of higher level, usability related questions that have to be figured out. ## General Workflow **How will navigation in the virtual world happen?** Early on, we should decide how navigation in the VR view will work. It should probably be usable with and without handheld controllers. Other VR engines have already implemented their solutions, which may be useful as a reference. **How can we create workflow specific VR UIs?** It would be nice if VR UIs could be integrated well with other workflow mechanics we have in Blender. For example there could be a simplified UI for 101-like templates, or specialized sculpting UIs. A version with focus on accessibility might also be interesting, VR offers new approaches for handicapped access. Basically we shouldn’t set one VR UI in stone, but allow people to come up with better or alternative solutions for specified use-cases. We’d still deliver a polished default experience obviously. This has big technical implications, as it influences how tools, operators, gizmos and other graphical elements have to be implemented. ## Operators, Tools & Gizmos **How will operators, tools and gizmos work together in VR?** Will we only provide the active-tool concept, or can we allow non-modal operator execution as well? How will tools and operators be selected/invoked? **How can users customize keymap bindings of controllers?** Note: The OpenXR specification “outsources” this part to the runtime. In Blender we would listen to abstract actions (e.g. “Teleport”) and the OpenXR runtime (Oculus, Windows Mixed Reality, etc.) binds this to a device button/gesture. This makes our job easier, we don’t have to care for device specific keymap bindings. So assuming we don’t need to listen to device specific button events (which might still be needed), OpenXR already answered this question for us. ## Setup **How is the VR reference space defined?** What’s needed is a point in space that acts as the origin of the VR experience, a up direction and an initial direction to look at (always perpendicular to the up direction?). Note that the up direction and the origin basically define the floor plane. The OpenXR runtime calculates the head position/rotation based on that, including eye level above the ground. It can also define the room/movement boundaries. Other engines probably already figured this out and we may be able to copy them. **How can settings be accessed from within the VR session?** There are different settings to think about: Viewport settings, VR-specific settings (e.g. toggle positional tracking), operator settings, tool settings, etc. We’d probably not expose properties editor or user preference settings for now, although we could make it possible to show any editor in a 3D floating popup. **How can users change settings for the VR session, but outside of it? Do we allow this at all?** For example, users may want to change viewport settings from the regular 2D UI, because the VR session renders too slow. This also matters for users that don’t have controllers. **How are session defaults and startup settings defined?** This is mainly about viewport settings (display mode, lighting, shading, etc.) and VR specific settings. You may want to set these up even before the session starts. And you may want to set your own default settings, too.
Author
Owner
Added subscribers: @dfelinto, @JulianEisel
Added subscriber: @SimeonConzendorf
Added subscriber: @RainerTrummer
Added subscriber: @Somnolent
Added subscriber: @aronkvh
As an outsider noob, I'd make a suggestion to check out this SketchUp extension , how they managed to achieve simplicity and efficiency (in SU which is a slow and shit program and this is the only reason I still use it).
As an outsider noob, I'd make a suggestion to check out [this SketchUp extension ](https://vrsketch.eu/index.html), how they managed to achieve simplicity and efficiency (in SU which is a slow and shit program and this is the only reason I still use it).
Added subscriber: @Sj
Added subscriber: @Skyfish
Adobe is plowing ahead in this field after they bough "oculus medium". I used medium quite a bit (vive + steam + revive) and would say it is intuitive and not overly complex how they solved their UI. In the new "Adobe substance 3D modeler" where theu use tech from "medium", Adobe is now increasing complexity and adding more and more feature that look intuitive and relatively minimalist while still retaining function, it's a nice case study for seeing how UI in VR modeling can be done. Here is a video that shows basic operations. https://youtu.be/DR6U2tX_73A
There are a few other VR apps that it benefits to study how they try to solve these same challenges. Like "Kodon" https:*store.steampowered.com/app/479010/Kodon/ (trying to do both sculpting and poly modeling seperately) and Masterpiece studio (was best at sculpting (not tried the studio version) https:*masterpiecestudio.com/ as well as Gravity sketch https://www.gravitysketch.com/ (has interesting takes on how to UI pollymodeling two handed)
I am an artist, with not much tech knowledge, but if there is an arena I can partake in discussion or test UI (with help) I have vive headset and index controllers.
RSI (repetitive strain injury) is something to consider when designing UI for VR. I find that sculpting in VR can be tiring, holding the arms stretched out takes a toll fast.
The benefits of sculpting in VR is very high, I am 5 times faster in Medium than Blender. (Not exaggerating)
Adobe is plowing ahead in this field after they bough "oculus medium". I used medium quite a bit (vive + steam + revive) and would say it is intuitive and not overly complex how they solved their UI. In the new "Adobe substance 3D modeler" where theu use tech from "medium", Adobe is now increasing complexity and adding more and more feature that look intuitive and relatively minimalist while still retaining function, it's a nice case study for seeing how UI in VR modeling can be done. Here is a video that shows basic operations. https://youtu.be/DR6U2tX_73A There are a few other VR apps that it benefits to study how they try to solve these same challenges. Like "Kodon" https:*store.steampowered.com/app/479010/Kodon/ (trying to do both sculpting and poly modeling seperately) and Masterpiece studio (was best at sculpting (not tried the studio version) https:*masterpiecestudio.com/ as well as Gravity sketch https://www.gravitysketch.com/ (has interesting takes on how to UI pollymodeling two handed) I am an artist, with not much tech knowledge, but if there is an arena I can partake in discussion or test UI (with help) I have vive headset and index controllers. RSI (repetitive strain injury) is something to consider when designing UI for VR. I find that sculpting in VR can be tiring, holding the arms stretched out takes a toll fast. The benefits of sculpting in VR is very high, I am 5 times faster in Medium than Blender. (Not exaggerating)
Added subscriber: @JacobMerrill-1
we have openXR included and there is an api we can use to create context to call bpy operators / bmesh /etc using VR handles already,
the VR addon needs extended to include sculpting and modeling easier for sure.
we have openXR included and there is an api we can use to create context to call bpy operators / bmesh /etc using VR handles already, the VR addon needs extended to include sculpting and modeling easier for sure.
Added subscriber: @CrivenS
Just joined solely as I really want to be able to sculpt directly in blender in VR. Adobe medium is nice and all but Blender is where its at. My background is arts and I'm attempting from scratch to figure out what is required to add this functionality any assistance I can offer by way of testing designing Ui etc is freely given.
In another different but related note, Open Brush is also Python, Open source and ready made is there some way it could be rolled in? https://openbrush.app/
Just joined solely as I really want to be able to sculpt directly in blender in VR. Adobe medium is nice and all but Blender is where its at. My background is arts and I'm attempting from scratch to figure out what is required to add this functionality any assistance I can offer by way of testing designing Ui etc is freely given. In another different but related note, Open Brush is also Python, Open source and ready made is there some way it could be rolled in? https://openbrush.app/
Philipp Oeser removed the
label 2023-02-09 15:15:29 +01:00
9 Participants
Reference: blender/blender#68994
