Improve handling of embedded data-blocks (root nodetrees and master collections) #69169
8 Participants
Reference: blender/blender#69169
Embedded data-blocks often require specific handling in ID management (freeing, duplicating, referencing, RNA paths, etc.).
Characteristics of embedded IDs:
They are flagged as such with
LIB_EMBEDDED_DATA
. This owner ID takes care of their management (creation, duplication, deletion...).** IDTypeInfo provides a way to get that unique owner ID from an embedded one.
However, they can be referenced by other IDs (e.g. master collection of scene can be a parent of many other collections). New embedded IDs are created with
LIB_TAG_NO_MAIN
, however existing old ones may not have it, and there is nodo_version
to set it on those...session_uuid
.bhead->code
set to their ID type.Proposals for Improvements
Here are ideas to help improve handling of the embedded IDs.
1 - Storing a reference to owner ID in embedded ones
While 'loop-back' ID pointers can be problematic, their support in general ID management code is now fairly safe and sound. This would solve the current issue where we have to loop over all potential owner IDs to find the proper one.
id_owner
pointer inID
struct itself, or in data of each specific ID type? D15838,cd49fee741
Would rather go for generic pointer inID
struct.2 - Tags and Library of embedded IDs should match their owner's
Embedded IDs should share the same 'ID management' tags as their owner ID (if owner ID is
LIB_TAG_NO_MAIN
, its embedded ones are too, etc.). Embedded IDs are not stored inG_MAIN
, but are often handled as such, can be referenced by other regular IDs (like master collection being parent of other collections), etc. Similarly, they should also always share the same Library pointer as their owners.788952705c
just adds some extra asserts to double-check that on file read.3 - Generic 'foreach' looper over embedded pointers only
This could help making some of IDManagement related tasks more generic when dealing with embedded pointers, needs to be investigated further.
There can be two approaches:
foreach_id
API (akaBKE_lib_query
). This implyIDTypeInfo.foreach_id
callbacks of types that may own embedded IDs to be aware of this option, to optimize their code by only processing those embedded pointers. Least effort solution, but requires exposing some info from generic foreach_id code into types callbacks. not necessarily a bad thing though.IDTypeInfo
, that would be somewhat the complement to the existingowner_pointer_get
one.Original task (note that since 2019, we clearly moved towards the second solution described below):
bNodeTree
is currently both a datablock, and embedded in materials. Same for collection and master collection of a scene.This leads to messy datablock management and problems creating RNA paths (e.g. #68971).
A solution to this could be to make
bNodeTree
node longer a datablock. Instead it would be embedded inMaterial
,World
,Light
, and a newNodeGroup
datablock.This will require Python API breakage and some relatively complicated versioning, but the resulting design should be cleaner.
Another solution is to design a proper handling of those private data-blocks all around our code base (ID/Lib management in BKE_library area, RNA handling of IDs, etc.). We already do that to some point, but so far it has mostly been hacks around issues on a case-by-case basis.
Solution to #68971 already added a new ID flag to mark those private datablocks, e.g. we could extend RNA handling of IDs to detect that one and automatically consider those structs as the other private sub-data ones (like e.g. render settings from scene, etc.).
Added subscriber: @brecht
#86119 was marked as duplicate of this issue
Added subscriber: @MACHIN3
Improve embedded nodetree storageto Improve embedded nodetree/master collection storage & handlingAdded subscriber: @Pipeliner
Added subscriber: @BartekMoniewski
Added subscriber: @Imaginer
Improve embedded nodetree/master collection storage & handlingto Improve handling of embedded data-blocks (root nodetrees and master collections)Added subscriber: @mont29
This seems generally fine.
I'd personally try to save memory and put
id_owner
in specific datablocks that are embedded, but not a big deal either way.
