black render of mirrored object - cycles #70561
Closed
opened 2019-10-05 16:46:15 +02:00 by Artur · 14 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f5449
when using the mirror the mirrored object come as black. Ive checked for overlaping and copied faces, recalculated normals. I had bevel but I removed it and it still comes as black. Eevee seames to work
The element come from sketchup exported to obj and imported to blender. I baisically recreated the geometry in edit mode using just a section from the importet geometry and extruded it and finally mirrored. bug.blend
**System Information** Operating system: Windows-10-10.0.18362 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86 **Blender Version** Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: `f6cb5f5449` Worked: (optional) **Short description of error** when using the mirror the mirrored object come as black. Ive checked for overlaping and copied faces, recalculated normals. I had bevel but I removed it and it still comes as black. Eevee seames to work **Exact steps for others to reproduce the error** The element come from sketchup exported to obj and imported to blender. I baisically recreated the geometry in edit mode using just a section from the importet geometry and extruded it and finally mirrored. [bug.blend](https://archive.blender.org/developer/F7791097/bug.blend) ![black mirror.png](https://archive.blender.org/developer/F7791099/black_mirror.png) [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @arturmachura
Added subscriber: @Russ1642
Added subscriber: @dark999
can confirm this problem on linux Blender 2.80 f6cb5f5449 (Stable), OpenSUSE Tumbleweed/KDE, AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 435.21, Factory Setting applied, LoadUI and Trusted Source disabled in file browser, same problem in Blender 2.81 ab519b91b2
this problem is visible in Solid, Material Preview (Lock Dev) and Rendered viewport, if i apply subdivision to object, problem disappear ans it is show as original mirrored object instead to be black
can confirm this problem on linux Blender 2.80 f6cb5f54494e (Stable), OpenSUSE Tumbleweed/KDE, AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 435.21, Factory Setting applied, LoadUI and Trusted Source disabled in file browser, same problem in Blender 2.81 ab519b91b2c4 this problem is visible in Solid, Material Preview (Lock Dev) and Rendered viewport, if i apply subdivision to object, problem disappear ans it is show as original mirrored object instead to be black
Added subscriber: @mano-wii
Germano Cavalcante self-assigned this 2019-10-08 16:34:38 +02:00
It is not a bug. This geometry has Custom Normals.
Delete the Custom Normals if you want the original normals.
It is not a bug. This geometry has `Custom Normals`. Delete the `Custom Normals` if you want the original normals.
Germano Cavalcante removed their assignment 2019-10-08 16:43:40 +02:00
Bastien Montagne was assigned by Germano Cavalcante 2019-10-08 16:43:40 +02:00
Added subscriber: @mont29
On second thought, Custom Split Normals should be mirrored as well.
This is how it worked in blender 2.79
@mont29, this seems to involve more modifiers than viewport.
Do you know what may be happening?
On second thought, Custom Split Normals should be mirrored as well. This is how it worked in blender 2.79 @mont29, this seems to involve more modifiers than viewport. Do you know what may be happening?
This issue was referenced by 47b95a2957
This issue was referenced by 47b95a295706c3092e48a227b50360748f8789be
there is code in that modifier to handle custom normals, just not using the proper transform for normals… Fix incoming.
Author
Thank you @mano-wii and @mont29
6 Participants
Reference: blender/blender#70561
