DRW: Colormanagment of Gizmos and Addon callback #74139
8 Participants
Reference: blender/blender#74139
During overlay color management refactor (
804e90b42d
), we changed the rendering of overlay to a sRGB render target that ensure blending in linear space.Overlays
This change some effects as blending was previously done in sRGB space which had a better perceptual progression.
Theses needs a case by case fix. There is no workaround possible.
Addons
During the developpement of the patch we saw that refactoring the gpu shader to output linear color would be too much work.
We tried a workaround to disable sRGB GPU encoding when rendering to the overlay buffer for the gizmos and callbacks drawing.
However this breaks alpha blending in both gizmos and callbacks (addons), here is the reason:
Previously the callbacks and gizmos where rendered directly on top of the composited viewport image in an sRGB color space. Blending would occur in sRGB and blend with actual colored pixels. The blending would not be radiometrically correct but good enough in practice.
Now we render all the gizmos and callbacks to the same overlay buffer that only contains overlays with premultiplied (unassociated) alpha to allow a wide range of effects.
When doing compositing for the final blit to screen, we read the sRGB render target. This texture is automatically converted by opengl to linear color during sampling.
We do the compositing in linear color and transfer back the result to Display Encoded Color space (aka sRGB in most cases).
And this is where all the problem resides. See the gizmos were rendered with alpha blending in sRGB space. So the light ratios are correct if interpreting the resulting color in sRGB space.
But we are converting the color back to Linear space. The light ratios resulting of the masking don't match anymore and you get darker results in alpha blended region.
Example rendering white pixels over transparent background with Alpha 50% (this is the majority of the cases):
IMPORTANT: The issue resides in the fact that we use both rendering mode on the same render target. And that we don't have the real final color "below" to interpolate in sRGB space like before to balance the "incorrectness" of it.
This issue was reported by @gfxcoder on twitter. https://twitter.com/gfxcoder/status/1231320641757962240
So what choice do we have:
pow(color, vec3(1.0 / 2.2))
could do it.IMPORTANT: Note that even if we fix the colorspace issue the blending will be different as it will happen in Linear space. Requiring manual tweaks to be done on the alpha value itself. Just like we did with the overlays.
The Fix
The quick hack:
Another more correct approach would be to inject a function that do the right transform to all custom shaders and gizmo shaders.
Note that for this fix to work we do need to remove this:
DefaultFramebufferList *dfbl = DRW_viewport_framebuffer_list_get();
DRW_state_reset();
GPU_framebuffer_bind(dfbl->overlay_fb);
GPU_matrix_projection_set(rv3d->winmat);
GPU_matrix_set(rv3d->viewmat);
/* annotations - temporary drawing buffer (3d space) */
Added subscribers: @gfxcoder, @fclem
Added subscriber: @EAW
Added subscriber: @Imaginer
Added subscriber: @BYOB
Added subscriber: @1D_Inc
The sooner the better I guess. Low price for the right decision.
Any update on what the plan is to solve this? I see that @fclem committed something for gizmos; does this fix
gpu.shader.from_builtin
and work for custom draw operators in addons as well?Added subscriber: @brecht
D7261: GPUShader: Implement workaround for gizmo drawing on sRGB framebuffer is the fix for this but it has not been committed yet.
Ok so I've commited the fix for addons.
The only change required is to use the new
blender_srgb_to_framebuffer_space
macro like this:out_color = blender_srgb_to_framebuffer_space(out_color);
where out_color is the fragment shader output variable which is initially in srgb space.
If addons are using builtin shaders, they are already converted.
IMPORTANT: This will definitely still change the output color when using blending. In this case the color values will have to get manually tweaked to get the desired result.
@fclem, be sure to add that information in the release notes:
https://wiki.blender.org/wiki/Reference/Release_Notes/2.83/Python_API
Added subscriber: @lemenicier_julien
Is there a plan to add this to 2.90? Or does this not apply there?
Sorry, it's there. thanks for the work!
