Undo system: Debug assert while undoing several operations #75919
6 Participants
Reference: blender/blender#75919
Graphics card: AMD FirePro W2100 ATI Technologies Inc. 4.5.13560 Core Profile Context FireGL 26.20.11024.6001
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-19 19:15, hash:
a331d79900
It appears as though there's some badness going on between selection, edit/object mode toggling, and perhaps modal operators? It's been very difficult to nail down for certain. What's below is the smallest repro I've been able to reliably hit the assert.
Start with default scene
Duplicate+Move the cube to the side
Select original cube
Select duplicated cube (don't shift select, just select normally)
Toggle edit mode
Subdivide
(De) Select all
Hit 3 to do Face select
Box select 4 faces of the cube
E then S to extrude then scale
Enable the Transform gizmo
Move the already selected faces
Toggle object mode
Ctrl-Z as far back as you can go
BLI_assert failed: F:\source\blender-git\blender\source\blender\blenlib\intern\BLI_ghash.c:462, ghash_insert_ex(), at '(gh->flag & GHASH_FLAG_ALLOW_DUPES) || (BLI_ghash_haskey(gh, key) == 0)'
Taken with
--debug-io --log "*"
Added subscriber: @deadpin
Added subscriber: @ankitm
couldn't redo on
5cc7e2ae16
is there a hidden setting I forgot to change for undo ?
Added subscriber: @iss
I also can not reproduce.
I can still reproduce as of
9618bd9202
If it doesn't trigger the first time, can you try running through the steps a second time using the same scene.
Added subscriber: @EAW
Crashed for me on the first try but not the second. Investigating.
Added subscriber: @ideasman42
I have been able to reproduce on both a release build and a debug build running in debug mode. It happens when I start up with my default scene using various --debug commands in the CLI, and then load factory defaults from the menu. I haven't gotten it to occur when I use --factory-startup in combination with --debug from the command line.
The assert was added by @ideasman42 back in 2013.
fbb446dff6
@iss @ankitm are you running in debug mode, and are you using factory startup?
I probable wasn't able to reproduce, because I haven't run with any --debug argument.
Added subscriber: @mont29
earlier no, now I tried that. but couldn't redo. --debug-io
Then did this, to get three cubes, couldn't redo.
then did some cycles of cmd + Z to get original scene and then cmd + shift + z to get final scene. After some such cycles, got the trace as in the report.
Very hard to reproduce for me, even more in debug builds... This is related to adding/removing objects, for some reasons once in a while 'things' get corrupted in the Object/Collection area. It can then trigger that assert or not, or crash in the collection update code, or in CoW code in depsgraph, or...
Managed to get it crash with
-t 1
so don't think this is a threading issue.Added subscriber: @brecht
I haven't been able to reproduce this problem, so this is just speculation.
From the backtrace and steps to redo, I think somehow we end up in a situation where two bases point to the same object, which triggers the ghash assert. This seems at least not caused by depsgraph or recalc flags, as the collection sync has the problem on original data.
I would guess that somehow
fd->libmap
ends up mapping two different pointers to the same object. This would mean either the wrong object is found by undo restore (duplicate session ID, some issue inold_idmap
, ..). Or there is something wrong with the way we construct or usefd->libmap
.What I still find odd in the undo restore code is putting the current ID pointer in there. Maybe this can end up being the same as another
bhead->old
value? Things still seem to work correctly without it, and I'm not sure why it is needed.So for those who can reproduce, it would be good if this patch can be tested. Even if it's wrong it might give a clue.
@brecht i think you nailed it. At lest when removing those two lines I cannot reproduce any crash anymore, while with current code and file attached below it is fairly easy (just duplicate a few times the whole selection of objects, and undo/redo, usually crashes fairly quickly for me).
undo_redo_crash_ID_creation.blend
I'd like to rethink this tomorrow with a fresh head though, want to recheck the cases where those would/could be needed again...
Was testing this with the details given in #914819 when I got this error while doing undo redo cycles:
Also, can confirm that applying the patch stops crashes in both, the file "undo_redo_crash_ID_creation.blend" & the original steps with the modifications in #914819
Yeah, in fact those mapping entries were needed when we were still lib-linking the whole set of data-blocks. Now we are only ever lib-linking IDs that were actually re-read during that undo step, so we can get rid of those (and avoid the conflicting memory addresses caused by repetitive re-allocations that will happen when undoing/redoing IDs addition/deletion.
Fixed by
0faeca806c
