Alembic: Wrong result when exporting and importing curves #76746
7 Participants
Reference: blender/blender#76746
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006
Broken: version: 2.90 (sub 1), branch: master, commit date: 2020-05-12 22:14, hash:
f9d0f59bed
Worked: never
I'm not familiar with the alembic exporter, but the result of exporting and importing curves doesn't seem right because the coordinates of the vertices are messy.
The result is messy curves.
curves_to_alembic.blend
Added subscriber: @mano-wii
Added subscriber: @dr.sybren
Alembic: Problem when exporting and importing curvesto Alembic: Wrong result when exporting and importing curvesThis has to do with Blender supporting multiple curve types in one Curve object, which isn't possible in Alembic. I can update the Alembic exporter to detect such situations and then simply only export the curves of one type and skip the others. Although that'll make the Alembic file incomplete, that way at least it should be valid.
I'm postponing this until after 2.83, as this requires a more thorough refactor of the existing Curves exporter. Doing this properly is easier with the upcoming refactor of the Alembic exporter, which is planned for 2.90.
The current curves exporter is severely limited; it ignores the curve type (
Nurb::type
) and tries to deduce the type to write from the existence of data in eitherNurb::bp
orNurb::bezt
. This will only work correctly in certain specific cases, which are unfortunately not documented.There is no clear (public) definition on how to write curves to Alembic. Writing curves properly, even when only aiming for compatibility with Blender itself, will require some design work.
In light of this, I'm changing this task's subtype from Bug to Known Issue.
Added subscriber: @lichtwerk
Added subscriber: @MSherak
Don't know if this will help, but here is a Alembic file exported out of Maya that can load into Blender and Houdini correctly. It's one Nurb curve exported. Maybe the deconstruction of the file will help with how curves are stored in Alembic so the they can be exported from Blender. MayaCurveExport.abc
Edit: Oh and set the Resolution Preview U to 3 and it will look like it does in Maya.
Added subscriber: @aplus
I ran into this a few months ago. From what I can tell a single curve will be exported fine, but as soon as multiple curves exist in same object, the exported curves in the alembic file will no longer match the original after alembic import.
I have attached blend file and alembic files of curves objects created with default settings and duplicated in EDIT mode, before export.
Hope this helps.
For nurbs, I noticed that the the points array for any curve that is not the 1st curve end up having a multiple of the number of points in splines[0]
... print (len(s.points))
10
10
10
20
curvesToAlembic.blend
nurbs.abc nurbsSub.abc
bezier.abc
README.txt
I would just like to add, that hair would be a classic example where export/import of alembic curves is needed. Right now the solution is to rely on another 3rd party software.
Hair curves are also most likely to be of the same type, so this may be a more feasible problem to look into and provide a solution depending on priorities.
Thank you.
This issue was referenced by
4c1393c202
