Cycles render crashes with open VDB sequence and motion blur on. #77854
9 Participants
Reference: blender/blender#77854
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
Cycles render, no matter CPU or GPU, immediately crashes when motion blur is on and there is a VDB sequence in the scene. I understand that VDB sequence by itself probably can not be affected by motion blur at all because this is just a sequence of independent frames. But anyway it would be nice if it would not crash the whole render process.
Download VDB sequence from here - http://www.mediafire.com/file/r8dmk4hr8ea0gmm/Gasoline_Explosion_01.rar/file
Import it to the Blender project using Shift+A - > Volume ->Import Open VDB
Set some volumetric material (I suppose this step is optional)
Switch render engine to Cycles
Turn on motion blur in render settings
Press Render
#77854.blend
Added subscriber: @Andrey_Sokolov
Added subscriber: @lichtwerk
Can confirm (also in
1d6529873f
).Assume this is a bug [unless there is something wrong with the metadata or how the VDB is written...]
Added subscriber: @kevindietrich
Is this still reproducible? I can't get it to crash on Linux, so either it was fixed somehow, or it's Windows only?
Added subscriber: @ANGRYWELSHMEN
I'm having this issue too. is it due to be fixed?
@ANGRYWELSHMEN, no one is trying to fix the bug at the moment. I could look into it, but I cannot reproduce the issue locally, neither with the master branch, neither in Blender 2.83.1.
Still having this issue In the Blender 2.83.1, Windows, branch: master, commit date: 2020-06-25 09:47. One more step to reproduce it is to animate the active camera: in this version Blender almost doesn't crash with VDB if nothing is animated. Also I've found out that it is possible to render without crashing from time to time if all 3 following checkboxes are checked in the Render Settings -> Performance: Use Spatial Splits, Save Buffers, Persistent Images. Unchecking any of them leads to crash. In the latest daily build of Blender 2.9 everything seems to work just fine, I can't reproduce this issue in it.
Appreciate it. My camera is animated so i'll try your fixes.
This appears to have been fixed already by
6ac235a6f7
, so closing this report.Added subscriber: @WhitecloudFX
No, its not fixed, have the same issue here, Blender 2.83.3, Windows 10 on a Titan RTX
Added subscriber: @SakuP
Hi.
I was having crash issues rendering VDB animation and had extensive tests and made a long detailed text already... but in the end I got mine tracked down to one clear issue.
VDB animation render crashes always when having Vector AOV (Passes->Data) on for Cycles render. Single VDB file (non-sequence) works with animation render with Vector pass on, but when having VDB sequence, then crash happens. Usually before very start of 1st frame render, but if the VDB sequence has offset, then sometimes crash happens just start of 2nd frame render. Nevertheless this is a bug and needs to be fixed. Better that someone else can also test and confirm.
Public VDBs used to reproduce crash:
https://jangafx.com/software/embergen/download/free-vdb-animations/
Files: Gasoline Explosion (751mb), Simple Fire (65mb)
I also found another bug:
System info:
Blender: 2.83.4
OS: Windows 10 Home
CPU: AMD Ryzen 7 2700X
RAM: 32gb
GPU: Nvidia RTX 2080 8gb
Regards,
Saku
@SakuP , @WhitecloudFX :
6ac235a6f7
is not backported to the 2.83 series afaict, could you check this with a 2.9 build from https://builder.blender.org/download/?@lichtwerk
I downloaded and did quick tests. Vector pass seem to work without crashes, but otherwise not stable at all.
Blender version used: blender-2.90.0-ba2d1c889819-windows64
This is first time I have tried 2.9 version, so I don't have stability reference on this Blender version.
Added subscriber: @brecht
Please create new bug reports, with example .blend files and exact steps to reproduce the problem.
Sure. I'll search first which ones are already reported and which ones not.
Question: How do you prefer to have bug report that is found in 2 different Blender version? One post and mention both Blender versions in description or 2 separate posts of same issue (one for each Blender version)?
One bug report is enough if it happens in multiple Blender versions, just mention the versions where it works or doesn't.
Added subscriber: @Skoffin
Working on a scene and after baking and re-importing my vdb I get an instant crash while the render compiles. is this related because i can't find an AOV pass checkbox, any help is greatly appreciated!
@Skoffin Please create a new bug report, with example .blend file and any other associated file and exact steps to reproduce the problem.
Added subscriber: @kaboose1066
What fixed this for me was changing the render tile size in render settings > performance > memory > tiling size from 2048 to 256, it slows the render down a bit but it least it renders, none of the other comments fixed it unfortunately.
