Library Override crashes: saving a scene / editing the override / switching scenes #78589
Closed
opened 2020-07-03 22:17:16 +02:00 by Georg K · 12 comments
Operating system: Linux-5.4.44-1-MANJARO-x86_64-with-glibc2.29 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.4.44-1-MANJARO, LLVM 10.0.0) X.Org 4.5 (Core Profile) Mesa 20.0.7
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-03 17:12, hash: 185fe9cd8b
Worked: 2.83
Blender 2.90 crashes on save if there is a library override and it crashes if the parameters of the library override are edited.
There is also another crash triggered by switching to a different scene
Crash #1/#2 (save/edit)
  • link the material from the source file {F8662182}(File - Link - MAT_Source.blend - Materials - MAT_from2.90)
  • assign the linked material to the default cube
  • add a library override to the linked material (Outliner - Blender File mode - select linked material - Add Library Override via right-click menu)
  • try saving the project OR try changing a parameter like the color
  • crash
Crash #3 (scene switch)
  • steps 1-3 from above
  • create new scene (or switch to a different existing scene)
  • undo (so you are back in the original scene)
  • switch to a different scene
  • crash
**System Information** Operating system: Linux-5.4.44-1-MANJARO-x86_64-with-glibc2.29 64 Bits Graphics card: AMD VERDE (DRM 2.50.0, 5.4.44-1-MANJARO, LLVM 10.0.0) X.Org 4.5 (Core Profile) Mesa 20.0.7 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-03 17:12, hash: `185fe9cd8b` Worked: 2.83 **Short description of error** Blender 2.90 crashes on save if there is a library override and it crashes if the parameters of the library override are edited. There is also another crash triggered by switching to a different scene **Exact steps for others to reproduce the error** Crash #1/#2 (save/edit) - link the material from the source file {[F8662182](https://archive.blender.org/developer/F8662182/MAT_Source.blend)}(File - Link - MAT_Source.blend - Materials - MAT_from2.90) - assign the linked material to the default cube - add a library override to the linked material (Outliner - Blender File mode - select linked material - Add Library Override via right-click menu) - try saving the project OR try changing a parameter like the color - crash Crash #3 (scene switch) - steps 1-3 from above - create new scene (or switch to a different existing scene) - undo (so you are back in the original scene) - switch to a different scene - crash
Author
Added subscriber: @georgK
Georg K changed title from Crash saving a scene with library override / editing the override to Library Override crashes: saving a scene / editing the override / switching scenes 2020-07-04 00:20:28 +02:00
Added subscriber: @mano-wii
I confirm the crash when trying to save the file.
Added subscriber: @mont29
Bastien Montagne self-assigned this 2020-07-08 17:46:49 +02:00
Overriding materials are not fully supported currently, nodes are as usual an issue... Will have a look though, should at least not crash
Fixed by e4926c167b (yes, wrong commit message :( ).
Author
Thanks! So basically you blocked using the override but not it's creation? Because while the testscenes do no longer cash, I still can't save my main project that already includes an overridden linked material (luckily, autosave does work).
Also
  • shift-clicking the material override icon of a linked material in the material properties editor
  • undo
  • shift-clicking the material override icon again
    crashes blender (sometimes requires going back and forth multiple times).
backtrace:
# Blender 2.90.0, Commit date: 2020-07-08 16:08, Hash e4926c167bac
bpy.context.space_data.recent_folders_active = 0  # Property
bpy.context.space_data.context = 'MATERIAL'  # Property
# backtrace
/home/georg//blender-git/build_linux/bin/blender(BLI_system_backtrace+0x33) [0x3e4fea3]
/home/georg//blender-git/build_linux/bin/blender() [0xb4ddce]
/usr/lib/libc.so.6(+0x3c3e0) [0x7f998eb393e0]
/home/georg//blender-git/build_linux/bin/blender(BKE_lib_override_library_operations_create+0x1f) [0xb9927f]
/usr/lib/libtbb.so.2(_ZN3tbb10interface78internal20isolate_within_arenaERNS1_13delegate_baseEl+0x46) [0x7f9996181136]
/home/georg//blender-git/build_linux/bin/blender() [0x3e53863]
/usr/lib/libtbb.so.2(+0x2c705) [0x7f9996187705]
/usr/lib/libtbb.so.2(+0x2c9cc) [0x7f99961879cc]
/home/georg//blender-git/build_linux/bin/blender(BLI_task_pool_work_and_wait+0xe8) [0x3e53678]
/home/georg//blender-git/build_linux/bin/blender(BKE_lib_override_library_main_operations_create+0xf0) [0xb99740]
/home/georg//blender-git/build_linux/bin/blender(BKE_undosys_step_push_with_type+0x2e2) [0x1616872]
/home/georg//blender-git/build_linux/bin/blender(ED_undo_push+0x7d) [0x146945d]
/home/georg//blender-git/build_linux/bin/blender() [0x14bc478]
/home/georg//blender-git/build_linux/bin/blender() [0x148067d]
/home/georg//blender-git/build_linux/bin/blender() [0x1491605]
/home/georg//blender-git/build_linux/bin/blender() [0xe0435a]
/home/georg//blender-git/build_linux/bin/blender() [0xe049cc]
/home/georg//blender-git/build_linux/bin/blender(wm_event_do_handlers+0x4ff) [0xe0529f]
/home/georg//blender-git/build_linux/bin/blender(WM_main+0x20) [0xdfb8e0]
/home/georg//blender-git/build_linux/bin/blender(main+0x33e) [0xb2030e]
/usr/lib/libc.so.6(__libc_start_main+0xf2) [0x7f998eb24002]
/home/georg//blender-git/build_linux/bin/blender(_start+0x2e) [0xb4a34e]
Just found another crash:
In the outliner, in Blender File mode, select Copy in the right-click menu of an overridden data-block.
Please consider hiding library overrides under experimental features until it is more complete.
Thanks! So basically you blocked using the override but not it's creation? Because while the testscenes do no longer cash, I still can't save my main project that already includes an overridden linked material (luckily, autosave does work). Also - shift-clicking the material override icon of a linked material in the material properties editor - undo - shift-clicking the material override icon again crashes blender (sometimes requires going back and forth multiple times). backtrace: ``` # Blender 2.90.0, Commit date: 2020-07-08 16:08, Hash e4926c167bac bpy.context.space_data.recent_folders_active = 0 # Property bpy.context.space_data.context = 'MATERIAL' # Property # backtrace /home/georg//blender-git/build_linux/bin/blender(BLI_system_backtrace+0x33) [0x3e4fea3] /home/georg//blender-git/build_linux/bin/blender() [0xb4ddce] /usr/lib/libc.so.6(+0x3c3e0) [0x7f998eb393e0] /home/georg//blender-git/build_linux/bin/blender(BKE_lib_override_library_operations_create+0x1f) [0xb9927f] /usr/lib/libtbb.so.2(_ZN3tbb10interface78internal20isolate_within_arenaERNS1_13delegate_baseEl+0x46) [0x7f9996181136] /home/georg//blender-git/build_linux/bin/blender() [0x3e53863] /usr/lib/libtbb.so.2(+0x2c705) [0x7f9996187705] /usr/lib/libtbb.so.2(+0x2c9cc) [0x7f99961879cc] /home/georg//blender-git/build_linux/bin/blender(BLI_task_pool_work_and_wait+0xe8) [0x3e53678] /home/georg//blender-git/build_linux/bin/blender(BKE_lib_override_library_main_operations_create+0xf0) [0xb99740] /home/georg//blender-git/build_linux/bin/blender(BKE_undosys_step_push_with_type+0x2e2) [0x1616872] /home/georg//blender-git/build_linux/bin/blender(ED_undo_push+0x7d) [0x146945d] /home/georg//blender-git/build_linux/bin/blender() [0x14bc478] /home/georg//blender-git/build_linux/bin/blender() [0x148067d] /home/georg//blender-git/build_linux/bin/blender() [0x1491605] /home/georg//blender-git/build_linux/bin/blender() [0xe0435a] /home/georg//blender-git/build_linux/bin/blender() [0xe049cc] /home/georg//blender-git/build_linux/bin/blender(wm_event_do_handlers+0x4ff) [0xe0529f] /home/georg//blender-git/build_linux/bin/blender(WM_main+0x20) [0xdfb8e0] /home/georg//blender-git/build_linux/bin/blender(main+0x33e) [0xb2030e] /usr/lib/libc.so.6(__libc_start_main+0xf2) [0x7f998eb24002] /home/georg//blender-git/build_linux/bin/blender(_start+0x2e) [0xb4a34e] ``` Just found another crash: In the outliner, in Blender File mode, select Copy in the right-click menu of an overridden data-block. Please consider hiding library overrides under experimental features until it is more complete.
Author
The copying crash is solved (version: 2.90.0 Alpha, branch: master, commit date: 2020-07-15 09:06, hash: e8b26a0501), but the other isn't. It seems to crash more reliably with:
  • click the icon again (to make fully local)
  • undo
  • crash
    Should I file a separate report or does this belong to "known issue"?
The copying crash is solved (version: 2.90.0 Alpha, branch: master, commit date: 2020-07-15 09:06, hash: `e8b26a0501`), but the other isn't. It seems to crash more reliably with: - shift-clicking the material override icon of a linked material in the material properties editor - click the icon again (to make fully local) - undo - click the icon again (to make fully local) - crash Should I file a separate report or does this belong to "known issue"?
Please create a new report yes, one issue per report. ;)
Author
Thanks, done: https://developer.blender.org/T78958
Reference: blender/blender#78589
