Sculpt mode. Performance issues after enable/disable dyntopo with zoom #79146
Closed
opened 2020-07-21 19:55:58 +02:00 by Vyacheslav Kobozev · 26 comments
{F8711949}System Information
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-10 20:07, hash: d2b910fafe
Same issue with blender-2.90.0-731d9f0bfa40-windows64 and 2.83.2 release
  1. Grab brush do not use dyntopo even in dyntopo mode as you know. But it start to work very slow with dyntopo sometimes even without zoom.
  2. After I switch off dyntopo back, all brushes start to work very slow.
So to reproduce:
  1. Zoom in to heavy mesh.
  2. Check speed of brushes on it.
  3. Switch to dyntopo, use grab a little.
  4. Switch back, check performance again.
I assume, that problems caused by dynamic mesh load/unload.
Please make it optional. It causes low fps, especially on dyntopo zooms.
{[F8711949](https://archive.blender.org/developer/F8711949/2020-07-21_21-01-12.mp4)}**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-10 20:07, hash: `d2b910fafe` Same issue with blender-2.90.0-731d9f0bfa40-windows64 and 2.83.2 release **Short description of error** 1. Grab brush do not use dyntopo even in dyntopo mode as you know. But it start to work very slow with dyntopo sometimes even without zoom. 2. After I switch off dyntopo back, all brushes start to work very slow. So to reproduce: 1. Zoom in to heavy mesh. 2. Check speed of brushes on it. 3. Switch to dyntopo, use grab a little. 4. Switch back, check performance again. I assume, that problems caused by dynamic mesh load/unload. Please make it optional. It causes low fps, especially on dyntopo zooms.
Added subscriber: @Vyach
#83808 was marked as duplicate of this issue
Vyacheslav Kobozev changed title from Sculpt mode. Performance issues to Sculpt mode. Performance issues with zoom 2020-07-21 20:06:26 +02:00
Added subscriber: @iss
I am unable to reproduce this issue. But this sounds more like a feature request than a bug.
try with this file
tstт1.7z
try with this file [tstт1.7z](https://archive.blender.org/developer/F8713560/tstт1.7z)
Can't reproduce even on your file. Does this happen when you click on File > Defaults > Load Factory Settings and retry steps to reproduce?
@iss yes, the same issue with factory settings.
Brush have no automasking. Mesh do not have multires.
2020-07-23_12-49-47.mp4
And here, when I add 2nd viewport Blender just hanging :(
2020-07-23_12-52-54.mp4
This problem started to annoy me since autohide was implemented. But usually I keep second viewport with fully loaded mesh, so it not appear in this case.
@iss yes, the same issue with factory settings. Brush have no automasking. Mesh do not have multires. [2020-07-23_12-49-47.mp4](https://archive.blender.org/developer/F8715633/2020-07-23_12-49-47.mp4) And here, when I add 2nd viewport Blender just hanging :( [2020-07-23_12-52-54.mp4](https://archive.blender.org/developer/F8715638/2020-07-23_12-52-54.mp4) This problem started to annoy me since autohide was implemented. But usually I keep second viewport with fully loaded mesh, so it not appear in this case.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I am not sure what the problem could be. It would definitly help if you could narrow this down somehow and I will re-check. Otherwise another developer with setup similar to yours would have to reproduce this.
@iss okay, I'll try to find more details.
One more setup with same issue.
win 10 pro
CPU intel i5 9400 2.9GHz
Blender version: 2.83.2, master, commit date: 2020-07-09 05:50, hash: 239fbf7d93, type: Release
build date: 2020-07-09, 04:24:13
GPU GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA
driver 4.5.0 NVIDIA 451.48
Another test on my machine (config in the topic)
version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: 375c7dc4ca
Have freezes for brush circle after making stroke, but not for brush action
2020-07-25_11-30-41.mp4
version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f5449 — fps for brush circle a bit slower, but not so noticable.
One more setup with same issue. win 10 pro CPU intel i5 9400 2.9GHz Blender version: 2.83.2, master, commit date: 2020-07-09 05:50, hash: 239fbf7d936f, type: Release build date: 2020-07-09, 04:24:13 GPU GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA driver 4.5.0 NVIDIA 451.48 Another test on my machine (config in the topic) version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: `375c7dc4ca` Have freezes for brush circle after making stroke, but not for brush action [2020-07-25_11-30-41.mp4](https://archive.blender.org/developer/F8719557/2020-07-25_11-30-41.mp4) version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: `f6cb5f5449` — fps for brush circle a bit slower, but not so noticable.
Common issue. With heavy mesh, fps in viewport go much lower just after enabling Dyntopo.
2020-08-27_10-52-18.mp4
CPU and GPU usage during rotation without dyntopo
And with dyntopo
What else can I test by my own?
Common issue. With heavy mesh, fps in viewport go much lower just after enabling Dyntopo. [2020-08-27_10-52-18.mp4](https://archive.blender.org/developer/F8813739/2020-08-27_10-52-18.mp4) CPU and GPU usage during rotation without dyntopo ![50062246.png](https://archive.blender.org/developer/F8813741/50062246.png) ![50073046.png](https://archive.blender.org/developer/F8813740/50073046.png) And with dyntopo ![50083648.png](https://archive.blender.org/developer/F8813745/50083648.png) ![50094348.png](https://archive.blender.org/developer/F8813744/50094348.png) What else can I test by my own?
Tested under Lubuntu. Issue is the same. So it is not OS/driver issue.
Added subscriber: @lichtwerk
I am out of ideas with this case.
@lichtwerk can you check this?
I am out of ideas with this case. @lichtwerk can you check this?
Member
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Member
I can confirm.
For me, it is even simpler to reproduce:
  • open highpoly sculpt file (or just throw a subdiv level 3-4 modifier on the default sculpting template sphere, apply)
  • zoom in
  • do a stroke (just to check "good" performance)
  • enable Dyntopo
  • disable Dyntopo
  • do another stroke (notice "bad" performance)
it looks like 2.82 behaves better, but I have not timed this yet
I can confirm. For me, it is even simpler to reproduce: - open highpoly sculpt file (or just throw a subdiv level 3-4 modifier on the default sculpting template sphere, apply) - zoom in - do a stroke (just to check "good" performance) - enable Dyntopo - disable Dyntopo - do another stroke (notice "bad" performance) it looks like 2.82 behaves better, but I have not timed this yet
Philipp Oeser changed title from Sculpt mode. Performance issues with zoom to Sculpt mode. Performance issues after enable/disable dyntopo with zoom 2020-08-28 16:03:56 +02:00
Even 2.79 have lower fps after еnabling dyntopo and slower Grab brush, despite Grab do not create new topology.
> In #79146#1004464, @lichtwerk wrote: > it looks like 2.82 behaves better, but I have not timed this yet Even 2.79 have lower fps after еnabling dyntopo and slower Grab brush, despite Grab do not create new topology.
Strange thing.
In 2.79 fps is low with dintopo+solid but become fast again with dyntopo+material
2020-08-29_17-46-25.mp4
With dyntopo enbled mesh uploading (unhiding) is few times slower.
2020-08-29_17-53-11.mp4
So it looks like a lot of unnecessary geometry uploading and unloading
Strange thing. In 2.79 fps is low with dintopo+solid but become fast again with dyntopo+material [2020-08-29_17-46-25.mp4](https://archive.blender.org/developer/F8819062/2020-08-29_17-46-25.mp4) With dyntopo enbled mesh uploading (unhiding) is few times slower. [2020-08-29_17-53-11.mp4](https://archive.blender.org/developer/F8819072/2020-08-29_17-53-11.mp4) So it looks like a lot of unnecessary geometry uploading and unloading
Added subscriber: @MeshVoid
Same performance issue appears on zoom after few minutes of work. Even without dyntopo.
Added subscriber: @JerBot
I'm experiencing a very similar issue, although I am not using dyntypo.
To trigger the lag, I only need to jump in and out of sculpt mode.
To fix, I zoom out and zoom in.
I'm on latest build(s) of Manjaro Linux using an nVidia 1060 w/ latest drivers (455). Can replicate this problem in Blender 2.91 and 2.92 Alpha (Dec 24th).
In the example, I'm using a freshly imported hi-poly OBJ file
  1. I activate sculpt mode and start sculpting and it's laggy.
  2. I zoom out to view the whole model, and immediately zoom back in and everything super fast and responsive.
  3. I deactivate and reactivate sculpt mode, and it's laggy again.
  4. I zoom out then in, and it's fixed again.
  5. repeat
Video demonstration.
2020-12-24_22-35-30_lagZoomFixDemo.mp4
Here's the Sketchfab (OBJ) model I'm testing on, which you can download and test for yourself.
Neytiri - Na'vi bust : by Reverse Imagineering
https://skfb.ly/6CINX
I'm now wondering just how long I've been experiencing this issue, as I've noticed significant jumps and drops in performance... for the past few months, at least. Most of the time I've been just experiencing the lag, and always wondering how everyone is able to have such snappy feedback. I often work with photogrammetry scans.
P.S. I hope you guys have good garbage collecting, as I've uploaded the demo video a handful of times, with different names, before I got it correct. Sry!
I'm experiencing a very similar issue, although I am **not using dyntypo**. To trigger the lag, I only need to jump in and out of sculpt mode. To fix, I zoom out and zoom in. I'm on latest build(s) of Manjaro Linux using an nVidia 1060 w/ latest drivers (455). Can replicate this problem in Blender 2.91 and 2.92 Alpha (Dec 24th). In the example, I'm using a freshly imported hi-poly OBJ file 1. I activate sculpt mode and start sculpting and it's laggy. 2. I zoom out to view the whole model, and immediately zoom back in and everything super fast and responsive. 3. I deactivate and reactivate sculpt mode, and it's laggy again. 4. I zoom out then in, and it's fixed again. 5. *repeat* Video demonstration. [2020-12-24_22-35-30_lagZoomFixDemo.mp4](https://archive.blender.org/developer/F9529442/2020-12-24_22-35-30_lagZoomFixDemo.mp4) Here's the Sketchfab (OBJ) model I'm testing on, which you can download and test for yourself. **Neytiri - Na'vi bust : by Reverse Imagineering** https://skfb.ly/6CINX I'm now wondering just how long I've been experiencing this issue, as I've noticed significant jumps and drops in performance... for the past few months, at least. Most of the time I've been just experiencing the lag, and always wondering how everyone is able to have such snappy feedback. I often work with photogrammetry scans. P.S. I hope you guys have good garbage collecting, as I've uploaded the demo video a handful of times, with different names, before I got it correct. Sry!
Added subscriber: @Likkez-2
This issue was referenced by 2ed6055209
This issue was referenced by 2ed605520959eca9c0ab3c497c85578e138936b4
Member
Pablo Dobarro self-assigned this 2021-01-05 21:03:22 +01:00
7 Participants
Reference: blender/blender#79146
