StretchTo constraint: Apply Pose as Rest Pose changes bone length #79553
5 Participants
Reference: blender/blender#79553
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.77
Broken: version: 2.83.3, branch: master, commit date: 2020-07-22 06:01, hash:
353e5bd749
Worked: never
bonelength changing to wrong length when apply new Rest Pose
add armature
subdivide bone in three bones,
select the top bone -clear bones
go to Pose mode
apply second bone a stretch-constraint to the last bone(tip)
rearrange the bones in Posemode to an new Pose
select with boxselect all bones
Apply Pose as Rest Pose (menu Pose, Ctrl A)
the green Bone with the stretch-constraint will have now a wrong bonelenght,
I'm not sure if this is a bug, but what seems strange to me is that the bone is displayed correctly in edit mode
workaround press reset inside the Add Bone Constraint
apply_new_Rest-Pose.blend
Added subscriber: @walt-3
Added subscribers: @dr.sybren, @iss
Not sure if this is bug, strictly speaking. @dr.sybren Should applying rest pose recalculate this value?
Added subscriber: @lichtwerk
I would think this is a bug (maybe it is a Known Limitation).
I think if you apply a new Rest Pose, one would expect also the mesh to not deform anymore.
With the current behavior, this is not the case, so you end up with a rest pose which already deforms.
set new Rest Pose change the bonelenghtto Apply Pose as Rest Pose change the bonelenght (due to StretchTo constraints rest length not being reset)Changed status from 'Confirmed' to: 'Needs User Info'
Please test this with a few older versions of Blender. Knowing whether a bug was recently introduced or has been in Blender for longer will help developers in finding the root cause of the issue.
behaves the same way in v2.80.75,
the versions before that I leave out
Thanks for testing this @walt.
This isn't so strange. The current pose is simply copied to the rest pose, which is what you see in edit mode. The Stretch To constraint applies a scale factor on top of the rest pose, and this scale factor is still the same after the operator has finished. This is why the bone becomes too long -- effectively the scale factor from the constraint is shown twice.
The code for the "Apply as Rest Pose" operator doesn't have anything for updating affected constraints or modifiers. The problem here is that the Rest Length property could have been adjusted by an artist, or even animated, so Blender can't just reset it and assume then everything will be alright.
Having said that, applying as rest pose will break existing animation anyway, so I think we can reset the rest length of the constraint.
yes exactly,
i would not use this anymore when i am done with rigging .
( just to avoid misunderstandings,
the "apply pose as rest pose" would mainly drop the rigging process.)
I have no idea what "dropping the rigging process" means.
In my test build, I have the "automatic reset button" working. It still produces a visual change, though. Edit bones don't have scale, which means that the stretching & squashing of the constraint (to maintain volume) cannot be copied to the rest pose. As a result, a bone that's stretched thin will become full size again:
@walt-3 Would this be the expected behaviour?
Apply Pose as Rest Pose change the bonelenght (due to StretchTo constraints rest length not being reset)to StretchTo constraint: Apply Pose as Rest Pose changes bone lengthThis issue was referenced by
a92ab93c7d
