v2.90.1 Silently crashes with EXCEPTION_ACCESS_VIOLATION while loading .blend file from Blender 2.6x #81468
Reference: blender/blender#81468
Graphics card: GeForce GT 1030/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.55
Broken: 2.82a to 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
Worked: 2.81a
Blender silently crashes when trying to open model from https://www.blendswap.com/blend/7951 (requires registration).
Observe the Blender crashes silently. No error message appears, - be it internal, or OS generated, - it just quits and that's all. I guess, that is not how it expected to work.
Added subscriber: @Arech
I learned that it's possible to make some logs, so here they are (spoiler: it's an access voilation exception actually that crashes the app):
blender_debug_output.txt
blender.crash.txt
blender_system_info.txt
And side comment: I'm using rather old AMD PhenomII X6 1090T processor. It does NOT have SSE4.1/AVX/AVX2 instruction sets, so it looks like that first lines of blender_debug_output.txt about CPU flags are incorrect if they are about my processor.
v2.90.1 Silently crashes while loading .blend file from Blender 2.6xto v2.90.1 Silently crashes with EXCEPTION_ACCESS_VIOLATION while loading .blend file from Blender 2.6x2.83.7LTS crashes with the same reason
2.69 seems to work
2.78c seems to work too (though, I can't get around "Blendfile Data" window that obscures all the view, but that is probably because my lack of familiarity with the app)
2.80 works too
2.82a crashes EAV
2.81a works!
Is there anything else I can help with?
UPD: I'm not sure that despite it loads in 2.81a, it works there properly (It displays the model in workarea with a better quality than it renders it with F12 (and the render result is significantly worse than I saw in 2.69) - It may happen because I'm total newbie with Blender and just doing something wrong, but I'll be very grateful if someone more experienced do the checks)
UPD2: also note, that opening-saving the file in 2.78c/2.81a still doesn't help to work with the newest version - it still crashes while loading the new file (the one created by 2.78c/2.81a). So, it's not the matter of incorrect/buggy original file, but some real issue with the file loader code.
UPD3 regarding render quality: indeed it seems that v.2.81a looses some (all?) textures during loading. When I open original file in 2.69 or in 2.78c and press F12 it renders properly, while doing the same in 2.81a results much poorer result without most of textures. This may indicate that old file format loader is broken in more than one point that causes access violation.
Added subscriber: @mano-wii
I can confirm that it worked on 2.81
The file does not appear to be corrupted, but there are some messages in the console:
@mano-wii Thanks for checking.
You've changed description as though it worked fine in 2.81. Did you also observe no textures are loaded in that version, though they loads/renders perfectly fine in 2.78c and prior versions? There may be more than one issue... If you can confirm there are no textures in 2.81, then I guess, another bug report should be created regarding textures?
This issue was referenced by
963b45f574
