Should "Make instances real" keep animation data from original objects? #81577
7 Participants
Reference: blender/blender#81577
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-25 20:54, hash:
83dc97ccc0
Make instances real removes object drivers.
Description:
In the attached file there is a cube which is included in a collection named "Box".
The cube has a simple driver on the location X axis.
In Scene.001 there is a collection instance of "Box" collection.
When i make instances real, new cube does not have the driver.
Steps:
Go to Scene.001
Select the collection instance
Press Ctrl+A > Apply Menu > Make Instances Real
Make Instances Real Removes Drivers.blend
#90773 was marked as duplicate of this issue
Added subscriber: @Yashar
Added subscriber: @lichtwerk
Not sure if this would be desired behavior in all cases.
Should it also copy regular Actions (not just drivers)?
Maybe this a candidate for respecting this User Preference as well?
Pointing out this is not a bug atm. it happens on purpose [just does
BKE_id_copy
- which does not copy animation data, and even explicitly removes animdata and constraintsBKE_animdata_free
/BKE_constraints_free
]Make instances real doesn't keep driversto Should "Make instances real" keep anitmation data from original objects?Added subscriber: @mont29
Definitively not a bug, at best a TODO if there is consensus to change that behavior.
@lichtwerk would not use those userprefs here, this is not a real copy…
I think if it is not a bug it is inconsistency when duplicating objects keeps drivers and make duplicates real doesn't keep.
What is the purpose of duplicating objects without drivers this way?
Collection instance and make duplicates real is a good way for duplicating and instancing objects among different scenes and it would be nice to have similar behaviors to standard duplicating.
Added subscriber: @dr.sybren
I wouldn't mind if animation data would be copied/referenced as well. The question is still whether to duplicate the Action, or to keep referencing the same one as the original.
Why is this not a "real" copy? What is a "real" copy, and how is this different? This isn't intended to sound as sarcastic as it might read, I'm genuinely interested.
@dr.sybren for me,
make instance real
primary usage is to generate objects from dupli objects (think particles), not really to be used on an instancing Empty (there are many other ways to do that from the outliner, and get proper instancing in viewlayer then, that you can duplicate in regular ways). In that sense, it's not like actively copying a selected object.I am mostly wary about case likes particle instances, do we want all of those instantiated objects to get animadata of the original as well? And if we follow the logic, then they should also get duplicates of obdata and materials if those options are enabled in user preferences as well…
How do you do that from the outliner? This is what I see when I go to Scene.001, then right-click on the "Box" collection:
None of these suggest "Make instance real" to me.
Good point.
@dr.sybren this is a viewport operation (
Object -> Apply
menu)From outliner you can only link in a collection instance to scene, not a real copy of collection.
Will set this to confirmed for now (so it forces us to have a look again or make a decision somehow...)
Should "Make instances real" keep anitmation data from original objects?to Should "Make instances real" keep animation data from original objects?Doh, thanks.
Would it be possible to distinguish between
When you have an animated object instanced via an empty, it the instance behaves as individual object. To me it would make sense to have the result of "Make Instances Real" try and preserve as much of its animation as possible. What do you think @mont29?
@dr.sybren should be possible yes,
DupliObject
has aparticle_system
member for instances generated by particles. Not 100% convinced this is the way to go though, at least this would need a very good documentation, since we'd have a single operator generating two completely different kind of results depending on the input data type...Think this is a topic of UI/UX department?
UI: no, but UX: yeah, probably it is.
I agree that having one operation perform different actions is not a good thing.
On the other hand, to me it doesn't make sense that the flow in this task (having a collection instanced, and being able to say "turn this into real objects") discards animation. It's a bit wider discussion than just the animation module, though, as it's also touching on generic data management.
Added subscribers: @BlenderTrek, @PratikPB2123
Is there any recent development about this question ? It has a strong impact for items instanced from Asset Browser to not be able to keep drivers.
As a motion graphics designer I say: It has to keep. More than that animation data has to be available to control animations within collection instances from outside, GeoNodes for examle, such as Mo-Graph in C4D can do with clones just with one simple effector.
Nowadays it is kinda freakshow and impossibilities to achieve good result without blowing mind.
