Keying set failed to set keyframes #82309
Reference: blender/blender#82309
Operating system: Windows 10
Graphics card: GTX 1050ti
Broken: 2.9
Fails to insert the desired keyframe and give the aforementioned error.
I pressed tab on the NarutoCrying track in Naruto Root and moved the location of bones around 13+03 and insert the keyframe. I am presented with that error.
As far as I have tested other actions should work fine.naruto__error_dev.blend
Added subscriber: @Lovely_Bigga
Added subscriber: @lichtwerk
Can confirm the behavior.
First note: blender complains specifically with
This might even be correct, will need some more investigation.
Added subscriber: @dr.sybren
Changed status from 'Confirmed' to: 'Needs User Info'
There is no 2.9, only 2.09 and 2.90. I'll assume this is about Blender 2.90.
Please test this with a few older versions of Blender. Knowing whether a bug was recently introduced or has been in Blender for longer will help developers in finding the root cause of the issue.
The example file is quite complex and even has multiple windows open. This is not a minimal example file that's suitable for a quick investigation by developers.
Yes, blender 2.90, I will give a new report tomorrow with minimal .blend file
Okay, so I tested different things and tried to resolve the bug/ error. I think the main problem may not be the error, since the error was valid in one sense although I feel it should have stated the problem directly.
I think the error is reproducible and not specific to my PC.
Here is the minimal blend file:
@lichtwerk correctly described the issue although maybe in more technical language.
The error arises because in NLA strip the keyframe range of the Action is between a certain range x to y(y being greater than x) when we try to add a keyframe at frame z such that zy, one gets the error message.
Keying set failed to insert keyframes, Now, a longtime user might be able to recognise this error and take action accordingly but for someone just learning blender, he may be lost and confused.
Whether blender should allow insertion of keyframes outside the region NLA of NLA track is up for debate and maybe more experienced blender animators can answer it more rigorously,
But my take is that it should allow insertion of keyframes since the NLA editor is a method for mild editing of action for use in the overall structure of bringing together all the actions and using them to produce a unified animation and as such actions are/should be independent of the NLA strip.
So the panel Strip->Action Clip-> Frame start and end
It seems to me that this is definitely a bug since blender in edit/tweak mode we are editing the action as we see fit and later we can choose how many frames we want to use via the Frame start and end of action Clip. There could be some anti-thesis that I am unaware of.
Tested in
Blender 2.83 LTS: Error Found
Blender 2.90: Error found
Blender 2.90.1: Error Found
Thanks for your time.
This should not be the case since "The NLA system now evaluates the strip based on the action bounds if it's flagged for syncing"
https://wiki.blender.org/wiki/Reference/Release_Notes/2.91/Animation-Rigging
89ee260ef2
In your case, this is already working fine for the
Sea_laying_02
Sea_laying_01.001
strips, but "fails" forNarutoCrying
,NarutoShocked
,finger movement
,NarutoSadLaying
:Turns out the reason for this is that the "failing" strips dont have
Sync Length
turned ON:If I turn this ON, then I can key outside the strip bounds, can you confirm this works for you?
@dr.sybren: Is there a reason why this is not always ON (cannot think of one atm. tbh)
But even with sync on if I tab to enter in tweak mode of action strip, and try to enter a keyframe out of bounds in
NaurtoCrying
animation I still cannot enter a keyframe at 314th (for example)frame.naruto__error_dev.blend
While in tweak action mode there is no option to SYNC NOW.
Steps to reproduce:
Select the NLA strip(NArutoCrying)-> Press TAB-> try to enter keyframe out of bounds of the NLA strip even after selecting Sync length. the error is reproduced.
Added subscriber: @wbmoss_dev
The sync-keyframing behavior was introduced in 2.91, not 2.90.1.
I can't reproduce the problem with these steps, using Blender 2.91 beta (
ada79b4707
). With Sync Length=ON, I can set a keyframe outside the strip bounds just fine.It is on by default for stashed strips (
dbb2b29bea
) but not for pushed-down strips. This was apparently chosen by Joshua (9b1ce6e556
, search for "(XXX) synchronisation of strip-length"), but not very strongly, as he writes "this decision is still subject to further review".I think that, with @wbmoss_dev 's recent improvements to how Sync Length works, it's now safe to enable by default. @wbmoss_dev what do you think?
I think it would be fine to be enabled by default.
@Lovely_Bigga can you give this another test with Blender 2.91, to see if it's still an issue? As I said earlier, I can't reproduce the issue myself.
Sorry for the late response.
Yes, with sync length ON I am able to set keyframes in Blender 2.91.
Hurray!
Changed status from 'Needs User Info' to: 'Resolved'
Since the issue has been confirmed in the past, and can't be reproduced any more, I'll mark it as resolved.
