Baked object rotation has discontinuities #83351
Reference: blender/blender#83351
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Worked: Never (2.80+)
I have a problem with animation curves after animation baking and after animation export. So you can see before/after.
It's rotation data. They're rotates on 180 degrees in X and Z-axis, and Y got to be symmetrical. It's happening after animation baking and animation export. What should i do to stay them as Before? Thank's!
Note: (@iss) script in text editor is pretty much copied from bake action operator, so I assume current behavior is bug, even though I havent found exactly what causes it.
#83351.blend
Added subscriber: @KoniFilms
Added subscriber: @iss
For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think this is bug, please clarify how exactly did you expor/import data.
I've opened the case in stackexchange, but got just one recommendation: to send it to you as the bug.
Just open my bug.blend file and do "baking animation" for the camera, you'll see changes in rotation data. If you'll do export in fbx you'll see it too.
Problems with rotation animation keys bakingto Baked object rotation animation is offsetChanged status from 'Needs User Info' to: 'Confirmed'
Baked object rotation animation is offsetto Baked object rotation has discontinuitiesAdded subscriber: @dr.sybren
The difference between your script and the Bake Action code is that your script doesn't do the conversions loc/rot/scale → matrix → loc/rot/scale. It's this conversion that causes the observed problems. The Bake Action operator is a bit limited in this sense.
You can select the rotation channels and then choose Key > Discontinuity (Euler) Filter in the graph editor menu. This will fix it right up.
Technical info: the Bake Action operator uses
euler.make_compatible(euler_prev)
to try and prevent discontinuities. This is not sufficient. The matrix → euler conversion has already picked one of the two possible rotations; see themat3_normalized_to_compatible_eul()
function inmath_rotation.c
for a proper implementation.This issue was referenced by
e5528904f1
The fix was too simple to not just immediately do :)
Changed status from 'Resolved' to: 'Archived'
I don't know what have you fixed. But i still have this problem with "Key > Discontinuity (Euler) Filter in the graph editor menu" before or after BakeAction. I need rotations value to be the same as before BakeAction or FBX-export. How could i fix it? What should i do?
Changed status from 'Archived' to: 'Resolved'
@KoniFilms please don't adjust the report status yourself, leave that to the developers working on it.
The image you see in the release notes is actually the file you attached here to this report. Which version of Blender are you testing with?
I tested 2.92 and looks like the problem is gone. Thank you so much guys! You're amazing!
