Boolean Modifier is evaluated if an object linked to the cutter object is link-duplicated #84156
Reference: blender/blender#84156
Operating system: Linux-5.4.0-58-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.38
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Suppose ObjectA has a boolean modifier, the target object of which is CutterA. CutterA shares the same mesh datablock as CutterB. If CutterB is link-duplicated (Alt-D), ObjectA 's boolean modifier is re-evaluated. In large technical scenes with many linked cutters this means Blender frequently stalls, re-evaluating every boolean in the scene every time you duplicate a cutter.
Expected behaviour: boolean modifier should only be evaluated if the cutter object datablocks change, and adding a user to a datablock should not count as a change.
Added subscriber: @cerebral
Added subscribers: @Sergey, @mont29
There are several sources for that update:
duplicate_exec
inobject_add.c
file) would also deg-tag obdata. This was probably needed with old depsgraph, but definitively not with the new one? either mesh remains the same, and there is nothing to tag, or a new one is added, and depsgraph will know by itself it needs to process it.deg_graph_on_visible_update
will 'tag' mesh ID with0
, i.e.LEGACY_0
, which it should most likely not use here.deg_graph_id_tag_legacy_compat
(which is currently called basically when tagging any ID for update) will currently systematically also tag withLEGACY_0
the object data, when called for an object.tagging the mesh for update will then trigger geometry updates of all its object users...
Points
1.
and2.
are fairly trivial to address, but point3.
is a bit of a rabbit hole, so would consider this more like a known issue.Here is a dummy patch fixing all three aspects of the problem - but the 'fix' for
3.
breaks even basic things like switching to Edit mode...P1865: (An Untitled Masterwork)
CC @Sergey for completeness.
