Loop selection corner case #84906
5 Participants
Reference: blender/blender#84906
Broken: 2.93 master
Worked: never?
(pun almost intended)
In the left image, alt-clicking the highlighted edge only selects that edge, whereas alt-clicking any other edge along that loop selects the whole loop (including that edge). However, if faces are extruded to make the mesh in the right image, then alt-clicking that edge selects the whole loop.
Note that even though the edge does border an n-gon, there's still a clearly defined direction for the loop as the edge leads to a 4-pole.
loop_selection_issue.blend
Added subscriber: @Stan_Pancakes
Added subscriber: @mano-wii
Thanks for the report I can confirm the problem.
Although there is an n-gon, in fact the behavior seems strange.
This is related to
01b3e9cc
Added subscribers: @ideasman42, @filedescriptor
I looked into this and found a "fix" (I am not sure if it has any side effects):
P1924: Potential fix for #84906?
That
if
that I removed gets executed when the lower edge with the n-gon in the example is (loop) selected. Later in the step function, we only walk along the n-gon if the next vertex has exactly 3 neighbours. when it does not, the iteration ends. This seems very strange.To summarize: I don't know what the use of the
f_hub
is or what theif
in thebmw_EdgeLoopWalker_begin
function should do. Sadly the comment on line 10 in the diff seems to incomplete. Removing thatif
(and therefore the use off_hub
) seems to fix the problem.@ideasman42 what are your thoughts on this? Do you know what that code is for?
This issue was referenced by
213f8294b5
@mano-wii & @filedescriptor, thanks for looking into this.
The
f_hub
was introduced in01b3e9cc9f
.This is the image linked (recovered from the archive) although the image along is still not enough to explain the behavior.
Committed more detailed description of this feature
1e355b0992
to avoid this kind of confusion in the future.
