Operators doing several different things can only have one tooltip (see e.g. Transfer weights tooltip). #85233
5 Participants
Reference: blender/blender#85233
There is currently no way to alter the tooltip of operators doing different actions depending on their settings.
Note that usually, the way to work around that is to create several operators using same code under the hood? If we accept that as a solution, then at some point we need document that in coding guidelines, and to check and address existing cases.
Original report
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.51
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash:
5be9ef4177
Weight Paint mode menu entry "Transfer Weights" tooltip says "Transfer data ... from active to selected meshes", but it appears to do the opposite.
Added subscriber: @skarkkai
Added subscriber: @filedescriptor
I can confirm this on the latest alpha and beta. It indeed seems like the active object's data is changed and the selected objects are not affected. The manual also disagrees with the tooltip: https://docs.blender.org/manual/en/latest/sculpt_paint/weight_paint/editing.html#transfer-weights
Added subscriber: @mont29
This is a generic known issue regarding operators' tooltips, there is only one tooltip, even if code can do several different things...
Though we had a task for that already, but apparently not, so will keep that one for that now.
Transfer weights tooltip wrongto Operators doing several different things can only have one tooltip (see e.g. Transfer weights tooltip).Added subscriber: @bbr20222
I was going to report the same bug and see that there is a fix that changes the tooltip depending on the use_reverse_transfer option. (Fix #85233).
But now I wonder where you can change this use_reverse_transfer option? There is no setting in the Adjust Last Operation popup.
After searching in the source I figured out that there are two menu entries that offer a weights transfer:
Wouldn't it be better to have a direction option (use_reverse_transfer) in the Adjust Last Operation popup dialog so users can see what's going on and can change it if needed?
This issue was referenced by
25ac6aa5e4
