crashes " Segmentation fault " #85991
Reference: blender/blender#85991
Operating system: Ubuntu 20.10
Graphics card: AMD Radeon RX 5700XT
Broken: 2.91.2 snap version / 2.92 latest 2210225 / 2.93 alpha
I'm getting all sorts of crash when importing images for textures, running viewport render, both in Eeve and Cycles.
Very unsure, since they happen on weird occasions. So far, on this files with 2.91 and 2.92 :
telegraphe.zip
Crash output from blender:
blender.crash.txt
Crash report when running
./blender --debug --debug-gpu > ~/blender_debug_output.txt 2>&1
also in terminal : Segmentation fault (core dumped)
And temp crash report:
telegraphe.crash.txt
Here is the lates crash with 2.93 alpha and
:debug output :
temp_crash report:
telegraphe.crash2.txt
Added subscriber: @skittlituted_scorpion
Here is an instantanous crash with 2.93:
telegraphe.crash3.txt
Added subscriber: @filedescriptor
Could you please be a bit more specific? The file has a dozen objects and nine materials. Please write down the exact steps for you to get the crash (or what you did before a crash happened).
Again, it's unclear what you mean by this. I see that there is a "pin" object, but multiple cube objects.
Note to self: When opening the file, I get a
GPUTexture: Blender Texture Not Loaded!
in the console.As of now, with latest 2.92 from snap and 2.93, when i open this file and try to create a collection, it crashes. It only once created the collection, but then crashed a short while after, and then i couldn't even create something.
telegraphe.blend
note, i cannot clean up the file because it crashes before i can save.
same error: segmentation fault (core dumped)
telegraphe.crash4.txt
what i meant with the list above with pin etc is that the cause and actions to reproduce are unclear for me as well ? It could be a hardware issue for all I know ...
I've been working on my file, and it seems to occur when I work with collections, and the fairly high-res images used as textures.
I haven't managed to reproduce on a smaller file unfortunately. There might also be crashes involving with boolean manipulations.
Anyone any tips of tests to see if it has anything to do with :
Got a Segmentation fault crash when i duplicated a cylinder used as boolean on my shape.
Before that a bus error crash.
temp crash report:
telegraphe_20210304.crash.txt
Both with alpha 2.93 from 2021/03/04
Could it be a problem of not enough memory/ram ? or blender cannot access memory ? It seems to be in cases of heavy textures and such.
had a segmentation fault on another program
@skittlituted_scorpion Could be, yes. How much memory have you got?
32 Go of RAM. Added 25 Go of swap to try and
Every time I have the Segmentation fault core dump, it's with a data intensive program (Blender, GimageReader - ticket: https://github.com/manisandro/gImageReader/issues/505, and one other that I unfortunately cannot remember...)
The crashes in blender don't occur when I'm rendering, weirdly enough. Mostly when moving, modifying collections.
Added subscriber: @lichtwerk
Looking at older reports again and trying to understand:
Just to be sure:
Help
>Save System Info
(to know which GPU driver version you are using -- at least one of the crashes seem to be in the radeon driver -- updating the driver to the latest version might also help https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html)Changed status from 'Needs User Info' to: 'Archived'
