Unwrap not unwrapping completely #86043
Reference: blender/blender#86043
Operating system: win7
Graphics card:
Broken: Blender 2.83.6
Worked: blender-2.92.0
Two polygons are stuck together by one vert. There should be 6 separate polys.
Create a Cube, select everything and mark all edges as seams, unwrap
2 polygons are stuck together by one vert
Pixels.blend
system-info.txt
Added subscriber: @BrahRah
Added subscriber: @lichtwerk
I am getting this from an unwrap (similar in both 2.83 and 2.93):
#86043.webm
Could you try to explain again exactly how you unwrapped to get them UVs stick together?
I selected every edge with A key then I pressed ctrl+e, then selected mark seam. U key -> unwrap. But I also tried to select the edges manually and unwrap but the results were the same.
The same you did in the video.
Hm, not sure how we could progress here.
Also noticed you mentioning this is working in a newer version (2.92) and not in 2.83 (LTS).
If this is fixed in a newer version, this would be a request for backporting this to 2.83?
Also: have you checked if this is still an issue in a fresh build from https://builder.blender.org/download/?
Added subscriber: @ankitm
In the given file, if the steps are repeated, correct staircase pattern shows up, instead of the report broken one.
Checked in 2.83.6, and 2.93 today.
Closing due to no response for over a week and not being able to redo with given steps.
Please report if it can be redone with any steps and we'll reopen the report.
