Remeshing object with subdivision modifier hangs Blender #86072
Open
opened 2021-02-28 05:39:51 +01:00 by Kuzey · 8 comments
Operating system: macOS 10.14.6
Graphics card:
Broken: All versions of Blender but tested on Version 2.93.0 (2.93.0 2021-02-25) & Version 2.92.0 (2.92.0 2021-02-25)
Worked: ?
1 Add a subdivision modifier to the default cube, set it to 2 or more.
2 Jump into Sculpt mode and remesh with default voxel settings, it should work fine.
3 Undo the last remesh and now change the voxel size to 0.002 m and remesh again, it hangs.
Do step 1 again, this time apply subdivision modifier and then try to remesh with voxel size of 0.002 m, it should work
**System Information** Operating system: macOS 10.14.6 Graphics card: **Blender Version** Broken: All versions of Blender but tested on Version 2.93.0 (2.93.0 2021-02-25) & Version 2.92.0 (2.92.0 2021-02-25) Worked: ? **Short description of error** Remeshing object with subdivision modifier hangs Blender **Exact steps for others to reproduce the error** 1 Add a subdivision modifier to the default cube, set it to 2 or more. 2 Jump into Sculpt mode and remesh with default voxel settings, it should work fine. 3 Undo the last remesh and now change the voxel size to 0.002 m and remesh again, it hangs. Do step 1 again, this time apply subdivision modifier and then try to remesh with voxel size of 0.002 m, it should work ![blenremesh2.jpg](https://archive.blender.org/developer/F9850222/blenremesh2.jpg) ![blenremesh.jpg](https://archive.blender.org/developer/F9850224/blenremesh.jpg)
Author
Added subscriber: @kuzey
Member
Added subscriber: @filedescriptor
Member
Member
I can confirm this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-01 06:12, hash: bfc70a6a95.
Note: I get a crash at BLI_assert failed: source/blender/blenkernel/intern/pbvh.c:2804, BKE_pbvh_vert_coords_apply(), at '!"PBVH: Given deforming vcos number does not natch PBVH vertex number!"' when I undo on step 3 with a debug build.
I can confirm this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-01 06:12, hash: `bfc70a6a95`. *Note:* I get a crash at `BLI_assert failed: source/blender/blenkernel/intern/pbvh.c:2804, BKE_pbvh_vert_coords_apply(), at '!"PBVH: Given deforming vcos number does not natch PBVH vertex number!"'` when I undo on step 3 with a debug build.
Member
Also, after Blender tries to consume all of my memory, I get this report from ASAN: P2001.
Also, after Blender tries to consume all of my memory, I get this report from ASAN: [P2001](https://archive.blender.org/developer/P2001.txt).
Author
Update:
This also happens with the subdivision + remesh modifiers (I'm not sure if I should make a new bug report, but it seems related, so I'll just add it here for now).
Step 1: Add a subdivision modifier to the default cube, set it to 2.
Step 2: Add a remesh modifier set it to .002m voxel size
works fine.
Step 3: Now move the remesh modifier to the top of the stack and Blender hangs
Cheers
Update: This also happens with the subdivision + remesh modifiers (I'm not sure if I should make a new bug report, but it seems related, so I'll just add it here for now). Step 1: Add a subdivision modifier to the default cube, set it to 2. Step 2: Add a remesh modifier set it to .002m voxel size works fine. Step 3: Now move the remesh modifier to the top of the stack and Blender hangs Cheers
Member
Added subscriber: @JulienKaspar
Member
Since the remesher creates a 6 million vertices mesh it would realistically not be able to handle a subdiv modifier set to level 2.
This crash even happens outside of sculpt mode.
I'd tag this as a known issue. There are many occasions where you could accidentally use operations that create/use a too high vertex counts and Blender hangs/crashes.
We need to implement warning messages to prevent users from doing this.
Since the remesher creates a 6 million vertices mesh it would realistically not be able to handle a subdiv modifier set to level 2. This crash even happens outside of sculpt mode. I'd tag this as a known issue. There are many occasions where you could accidentally use operations that create/use a too high vertex counts and Blender hangs/crashes. We need to implement warning messages to prevent users from doing this.
Philipp Oeser removed the
label 2023-02-10 09:12:01 +01:00
Reference: blender/blender#86072
