Boolean Modifier "Exact" solver does not apply target object material to created faces #86427
Reference: blender/blender#86427
Operating system: MacOS 10.13.6
Graphics card: NVidia GT 750M and Intel Iris Pro 1536 MB
system-info.txt
Broken: 2.93.0 alpha (blender-2.93.0-8618c4159c7b-macOS)
Worked: 2.92.0 stable
when using Difference or intersection, a boolean modifier operation creates new faces from the intersecting geometry. Those faces should get assigned the same material as the target boolean object chosen in the modifier. This is not happening when the Solver is "Exact".
boolean material.blend
Added subscriber: @BlenderBruno
Added subscriber: @filedescriptor
I can reproduce this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-10 04:47, hash:
70e73974b5
.Added subscriber: @howardt
@howardt This is probably something for you :)
I was trying to reproduce the behavior of Fast, but it seems I misunderstood that behavior. Some experiments seemed to show that Fast just used the same slot # in the final result that was used for the material of the faces on the source (cutter) object, so that's what I did (if you add two more slots of materials to the icosphere and put the magenta material in the 3rd slot, which corresponds to where that material is in the cube, then it works). Also, if the target doesn't already have the source material somewhere in one of its slots, Fast doesn't copy the material over to the target. This seems kind of broken too, but I guess should, for now, just try to emulate exactly what the Fast mode does, which seems to be: look up the source material in the targets material slots: if found, use that slot #; if not found, just use the same slot #.
This issue was referenced by
a01fb22f28
Thanks Howard and Team!
