enum_items not working with dynamic EnumProperty #86803
6 Participants
Reference: blender/blender#86803
Operating system: Windows 10
Broken: 2.91.2,
5be9ef4177
, master, 2021-01-19Short description of error
When using a callback to populate a (dynamic)
EnumProperty
, theenum_items
property available for thatrna_type
returns an empty collection.Exact steps for others to reproduce the error
Minimal script sample:
Output:
Added subscriber: @Hugo-Aboud
Added subscriber: @JaumeBellet
Issue here is that RNA_property_enum_items_ex function is called with NULL as context.
When calling the callback (to get the value for example), is scaled up from a BPY_context_get() call on bpy_rna.c
Added subscriber: @lichtwerk
I can confirm the behavior.
Trying to understand the usecase a bit better though (since these are 'expanded' correctly for the UI and elsewhere):
Why do you need access to these like demonstrated above?
While not as convenient as from 'proper expanded' collection of
EnumPropertyItem
, you could get them directly through the callback, no?See
#86803.blend
The issue came up while I was trying to setup dynamic nested Menus using
context_pointer_set
, as described here.Since the
data
argument must be ofAnyType
I need acess to theEnumPropertyItem
references.The solution for now has been populating the enum items when the annotations are evaluated. However, this can only be done once, not allowing for dynamic content changes.
Interesting usecase, confirming then.
Added subscriber: @ideasman42
Currently
enum_items
only works for static items. - That is a fixed array of items.For C/C++ code both can be set, for Python passing the item as a function makes it impossible
Marking as a TODO since this isn't an error in the code.
Found some other use case for this trying to make a general method to check wheither current enum value is valid to polluting console with errors like below:
WARN (bpy.rna): C:\Users\blender\git\blender-v360\blender.git\source\blender\python\intern\bpy_rna.c:1343 pyrna_enum_to_py: current value '17' matches no enum in 'BIMModelProperties', '', 'relating_type_id'
Idea of the method was:
I guess it still can be done manually by keeping track of each dynamic items generator in the code.
