Attribute Transfer Node #86843
5 Participants
Reference: blender/blender#86843
{F9904877 size=full}
This is task is for a port of the "Data Transfer" modifier to a node.
** A later improvement to the node could be to copy multiple attributes, maybe with a multi-socket input node.
** "Nearest": Copies attributes from the nearest element of the domain of the source attribute.
** "Nearest Interpolated": Similar to what happens in the point distribute node, interpolates values from the nearest vertices or edges on the closest face
** "Topology": Requires the topology of the target geometry to be the same, so really more of an "Attribute Copy" operation, otherwise outputs an error.
** More options may be necessary based on the choice for the destination domain.
Further Questions
** The "Max Distance" and "Ray Radius" options may be necessary.
Implementation
It's not clear how much the existing data transfer code would be useful, my guess is not much.
The "Attribute Proximity" node already does the same thing with the "position" attribute, so some logic could be shared with that.
Added subscriber: @victorlouis
As I understand it:
Nearest
mode of the modifier corresponds to thePoints
mode if the Attribute Proximity nodeNearest Interpolated
mode corresponds to theFaces
modeHowever the Attribute Proximity node only "transfers"
position
, so it's code would have to be extended to transfer arbitrary attributes (and interpolate them over triangle faces when needed).Yes, good points. Those names in particular could be improved I think.
Added subscriber: @SimonThommes
The way this is split up into details totally makes sense to me.
In terms of needed mapping methods I have a couple of thoughts:
Corner
domain, with for example UV seams. Even the current operator/modifier works far from ideal in this case.But I think additional needed methods can come if necessary.
WIP: Attribute Transfer Nodeto Attribute Transfer NodeChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @stratmann
The design of the underlying system has changed significantly. If improvements to the existing Transfer node are required, a new task can be created.
