Blender crashing while switching viewport #88425
Reference: blender/blender#88425
Operating system: Windows-10-10.0.19041 64 Bits
Graphics card: GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Worked: 2.92 is the only version I have
Blender crashing while switching from Layout to Shading to configure Dynamic Sky Plugin
Load up scene file, go from Layout to Shading causes memory spike and then crashes
BlenderTest.blend
Added subscriber: @Ty_Emery
I am a relatively new to Blender having come from Cinema 4D, was hoping to be able to switch to Blender but the constant crashing is non-productive and frustrating, I am trying to learn the software but it is somewhat impossible at this stage - I am using Cycles and have tried both CPU and GPU compute both with the same result
Added subscriber: @rjg
If the crash doesn't occur because you're running out of memory, then please open Blender's installation directory and double click on the
blender_debug_gpu.cmd
. This will start Blender in debug mode and create log files. Try to make Blender crash again. Once it crashes the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located inC:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt
(or simply type%TEMP%
into the path bar of the Windows Explorer).Thank you for your response, I have uploaded the debug and system info but I am unable to locate the crash txt file - I tried manually searching for that file but the only .txt files in that location are the debug and system info - what I don't understand is that everything was working fine for a while yesterday then it suddenly started crashing for no obvious reason bar the memory being pushed to its max, thanks again Robert
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @lichtwerk
https://docs.blender.org/manual/en/dev/troubleshooting/crash.html
@Ty_Emery If the memory is indeed reaching its maximum then the crash likely happens because you are running out of memory. It could be that your scene complexity is too high (e.g. geometry, modifiers, number of textures / texture size, number of particles). Please check if it works properly if you try to reduce the complexity and keep the memory usage from reaching the maximum.
Edit: I've just noticed that you've already attached the project file. One of us will have to take a look if we can reproduce the memory spike and if this is a bug or an issue in the scene complexity.
Tested the file and I pinned performance tab to track the spike. Memory spike did not occur and crash is also not reproducible.
