Click and Drag along Disclosure Triangles does not function as expected. #88528
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#88528
Pagename:
editors/outliner/introduction
Blender Version:
2.92
Documentation Language:
en
Permanent link
The documentation states that "LMB Clicking and dragging along disclosure triangles will expand or collapse multiple data-blocks."
This does not seem to work. Not sure if this feature was removed or is broken.
Added subscriber: @alwin
Added subscriber: @Blendify
This worked for me: 2021-05-24 20-16-13.mkv
Are you holding down the left mouse button?
Ah. I see. The way I interpreted the documentation was that you could open each sublevel using the click and drag. Instead the click and drag only works for data blocks at the same hierarchical level.
Maybe a change in the wording of the documentation to clarify this or gif to show how it works would be a good solution.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
This is working fine for me also.
@Blendify , do want to add any point here?
Manual part looks clear for me at least.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
