command line arg "--python-use-system-env" not working anymore #88930
6 Participants
Reference: blender/blender#88930
Operating system: Windows-10-10.0.18363-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 26.20.100.7263
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
I am using an external python installation with additional installed modules.
Out of an set python environment I started blender with the --python-use-system-env argument. Blender starts but the in addition installed packages cannot be imported.
Start of blender out of command shell:
Renamed blender python to python_
Made a link directory link to my conda python installation (same python version, additional installed packages) and named the junction link "python"
Start blender out of my conda environment:
Everything worked fine in Blender 2.92
Added subscriber: @schmti
Added subscriber: @Zandman
Why do you rename Blender's Python and use a directory junction link? Shouldn't it be that once you use
argument your custom Python stuff can simply be defined using environment variables, likePYTHONPATH
? No need to overwrite Blender stuff. I could be wrong.Added subscriber: @iss
Can not reproduce this issue, I have tried importing
flask
andcv2
modules, all were good. My python from https://www.python.org/downloads/release/python-395/. I don't have anything else like conda set up here.Added subscriber: @ankitm
https://developer.blender.org/P2184 There are differences indeed in 2.93 and 2.92's
sys.path
with the--python-use-system-env
flag.Added subscriber: @lichtwerk
Also cannot reproduce this (everything in
PYTHONPATH
ends up insys.path
for me with the flag), or cannot really tell why these steps are necessary:@schmti : is there anything in PYTHONPATH for you?
Reg. the differences @ankitm was noticing (the local
site-packages
/Users/ankitkumar/.local/lib/python3.7/site-packages
seems to be included in 2.92, but not in 2.93): same question here: @ankitm : is there anything in PYTHONPATH for you? Or is the addition of the the localsite-packages
purely "automatic"?Now since 2.93 uses python 3.9, do you have something like
/Users/ankitkumar/.local/lib/python3.9/site-packages
as well?Note: I have
.local
folders for both python versions, but they are not added automagically [neither with--python-use-system-env
nor without -- only if I put them in PYTHONPATH]https://docs.python.org/3/library/site.html#site.USER_SITE
I can't redo it anymore..
In 2.93.0, 2.93.5, 3.0, .local site package dir is added to sys.path when using
without using any env variable.Changed status from 'Needs User Info' to: 'Needs Triage'
Added subscriber: @OmarEmaraDev
I can't replicate this either. As mentioned before, this is probably not how you should install additional modules from another environment, can you try without messing with Blender's python?
Assuming you have some environment with a compatible python version, you can launch blender with
PYTHONPATH=/path/to/environment/lib/python3.10/site-packages blender --python-use-system-env
.Also see https://developer.blender.org/T75291#901886.
