Blenderkit: Online Asset not working in Prefrences #89080
Closed
opened 2021-06-12 08:08:55 +02:00 by ajay · 4 comments
Graphics card: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: blender/blender@0f45cab862
Addon Information
Name: BlenderKit Online Asset Library (1, 0, 32)
Author: Vilem Duha, Petr Dlouhy
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27 **Blender Version** Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: `blender/blender@0f45cab862` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: BlenderKit Online Asset Library (1, 0, 32) Author: Vilem Duha, Petr Dlouhy **Short description of error** [Please fill out a short description of the error here] **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @hypermyst
Member
Member
Member
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem. A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
2 Participants
Reference: blender/blender-addons#89080
