The problem that the software closes when you press the hair button in 2.93 #89084
Closed
opened 2021-06-12 14:04:24 +02:00 by jyun ino · 9 comments
Operating system:macOS catalina imac(retina 5k,27-inch late2015)
Graphics card:AMD Radeon R9 M380 2 GB
Blender Version2.93Broken
”Hair buttons can be used without problems in 2.83”
(example: 2.80, edbf15d3c0, master, 2018-11-28, as found on the splash screen)
When I press the particle hair button, the blender closes and I can't make it.
Install the blender, open it and press the hair button from the particles to close the software
**System Information** Operating system:macOS catalina imac(retina 5k,27-inch late2015) Graphics card:AMD Radeon R9 M380 2 GB **Blender Version**2.93Broken ”Hair buttons can be used without problems in 2.83” : (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) Worked: (newest version of Blender that worked as expected) **Short description of error** When I press the particle hair button, the blender closes and I can't make it. **Exact steps for others to reproduce the error** Install the blender, open it and press the hair button from the particles to close the software Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @jyun1002
#89086 was marked as duplicate of this issue
Author
Removed subscriber: @jyun1002
Member
Member
Member
Member
Thanks for the report. Can you check again with fresh build? (https://builder.blender.org/download/daily/)
>(example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen Thanks for the report. Can you check again with fresh build? (https://builder.blender.org/download/daily/)
Member
2.93Broken
Did not notice that. What happens after you load factory settings? (File -> Defaults -> Load Factory settings)?
Also attach the crash logs. (refer: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html#macos)
>2.93Broken Did not notice that. What happens after you load factory settings? (`File -> Defaults -> Load Factory settings`)? Also attach the crash logs. (refer: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html#macos)
Member
Closed as duplicate of #83199
Reference: blender/blender#89084
