Depsgraph use-after-free after scene switching undo #89196
Reference: blender/blender#89196
Operating system: Linux-5.11.0-7614-generic-x86_64-with-glibc2.32 64 Bits
Graphics card: Radeon Vega Frontier Edition (VEGA10, DRM 3.40.0, 5.11.0-7614-generic, LLVM 11.0.0) AMD 4.6 (Core Profile) Mesa 21.0.0
Broken: version: 3.0.0 Alpha
The
deg_graph_on_visible_update()
triggered by a scene change may access a master collection viaIDNode.id_orig
that was freed.Exact steps for others to reproduce the error
The attached .blend was prepared with the following steps:
T89196_depsgraph_scene_switch_undo_crash.blend
With the attached file:
ASan output: {P2182 lines=14}
Setting a breakpoint in
, I see that:IDNode.id_orig
of the iterated ID is indeed freed.IDNode.id_cow
has a name of "GRMaster Collection"So it seems the original ID pointer in the master collection (an "embedded ID") node is not updated when the scene is freed on undo.
Added subscriber: @Sergey
Will have a look in a bit unless someone else does it :)
I was looking into this a little bit and found that the following (wrong) patch would fix it. Maybe that helps someone.
I am not that much sure it is wrong even. In many usages usages (including the most important one in the even loop) the relations are updated prior to
DEG_graph_on_visible_update()
. Knowing relations are up-to-date does simplify a lot of things, probably without actual slowdown even.Not only from the use-after-free usecase, if the object is removed from DEG and DEG becomes visible, there is no need to tag that ID.
One thing I wanted to try is to convert
to the tagging flag. As in, tag depsgraph "please tag IDs as if the DEG became visible, whenever it is convenient for you". Then we can ensure valid access and order of things during DEG evaluation and do as following:This issue was referenced by
956c539e59
