Text datablocks don't self-register when getting a .00x suffix #89532
5 Participants
Reference: blender/blender#89532
Problem
Although all text blocks that don't have an extension use script highlighting, only those which end in exactly
.py
allow for the "Register" checkbox's functionality to work. I think this design forgot to take into account that Blender will slap a .001 suffix after duplicates datablocks, which can cause scripts to fail to register themselves pretty easily, and in a way that is very hard to troubleshoot for a user who is not in the know.Example cases
For example, someone might rig two characters in two files, and create rig UI scripts for them, both named
rig_ui.py
. Then, since they're working on a small hobby level production, they will append the characters into the same scene, resulting in the appended script getting a .001 suffix and failing to execute.In another case, one might want to append multiple of the same character, resulting in the same issue, and in this case naming the rig script in a unique way won't even help.
Even in a real production where linking allows these datablocks to have their own namespaces, sometimes there's small flaws in pipeline tools, or somebody makes a small mistake, and a script can end up with a .001 suffix in a plethora of ways.
Solutions
I would propose allowing scripts to use the Register feature not only if their names end in exactly
.py
but also.py.###
(I think there's already naming util functions to check for this)Alternative would be to put the .001 before the .py when a duplicate appears but I think that would require adding a special case to much deeper code which probably nobody wants to do ;).
This was also mentioned in an Animation Module meeting once upon a time and according to my memory there was general agreement toward the first solution, but my memories are faded and I'm biased.
CC @dr.sybren @BassamKurdali @LucianoMunoz @icappiello @jpbouza-4 Thoughts? :)
Added subscribers: @icappiello, @Bassam, @LucianoMunoz, @jpbouza-4, @dr.sybren, @Mets
Added subscriber: @BassamKurdali
Added subscriber: @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
can confirm the issue, will leave classification up to module devs
+1 for the first solution. The exact datablock name is less important now that they cannot be directly imported any more;
import rig_ui
used to work for importing a text datablockrig_ui.py
; now you needrig_ui = bpy.data.texts['rig_ui'].as_module()
for this.This might require changing the logic in
ED_text_is_syntax_highlight_supported()
a bit. Currently it always returnstrue
for any datablock ending in a.###
numerical suffix. If we say thatblabla.xxx.###
should be treated the same asblablabla.xxx
, the current logic in that function is not suitable any more.Furthermore,
TEXT_MT_text
should be adjusted. Currently it's the menu's Python code that determines whether the "Register" checkbox is enabled or not. IMO this is a bad design -- the ability to register a text datablock should be handled in RNA and not in UI code.Added subscriber: @ideasman42
Since the scripts are executed instead of loading as a module there is no longer a need to have any constraint on the naming.
Seems reasonable this can be handled separately.
This can't be done in RNA, it's only possible to conditionally be read-only, where as for this we would only want to grey it out.
Submitted D12181, this removes the check for the extension entirely.
This issue was referenced by
3e775a4fc5
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
