Segfault populating popup menu with specific structure, scale_x
, and element count. (GPUOffScreen buffer too large?) #89782
5 Participants
Reference: blender/blender#89782
Operating system: Linux
Graphics card: Intel
Broken: 2.93.0
I have a very specific UI hierarchy and settings that are consistently causing segfaults for me.
I think the short draw code is the best way to explain it:
.scale_x = 2
is needed for the crash. The number of items from therange()
also matters, and won't crash with too few or too many. I don't think the lengths of the labels matter.Also happens with column/row layout convoluted/zipped.
Also happens with
.ui_units_x = 40
replacing.scale_x = 2
(but not with all other values of.ui_units_x
).Actually seems to happen with some number (but not all numbers) of elements for any combination of UI dimensions in
.popup_menu
.Note: Even when it doesn't segfault, the popup menu will often be an obvious rendering error with lots of tearing and such.
Run the script:
ScaleXCrash.blend
Added subscriber: @WCN
Added subscriber: @lichtwerk
Can confirm.
note: does not happen if
scale_x
stays below 1 (at least here on my end)Added subscriber: @mano-wii
It is just that the
GPUOffScreen
buffer would be too large it seems and cannot be created.The assert can be avoided by the following (but still -- this should be safeguarded against more thoroughly since this gets blender into total unstable land):
{P2246}
@mano-wii: is this something you can look into?
Segfault populating popup menu with specific structure, `scale_x`, and element count.to Segfault populating popup menu with specific structure, `scale_x`, and element count. (GPUOffScreen buffer too large?)The error is in the internals of the GPU module. Not much related to the python API
The crash happens because the offscreen texture has dimensions above the OpenGL limit, and
GPU_offscreen_create
requires a non-NULLerr_out
arg.Checking if the
err_out
isNULL
would do the trick too.It can also be interesting to raise an error message in the interface.
I will propose a patch.
This issue was referenced by
15cfb375a3
Hm. There isn't any way to specify the popup menu size from the Python API though, AFAICT.
In fact, the example code produces a menu that's several times wider than it needs to be, with the majority of the menu being blank space.
15cfb375a3
has fixed this, right?I'll close this report. Please reopen it if problem persists
