Simple way to make Blender crash........ #89907
Reference: blender/blender#89907
Graphics card: Intel(R) UHD Graphics 630 Intel 4.5.0 - Build 26.20.100.7925
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-10 13:52, hash:
49a363f0e0
Simple way to make Blender crash, at least on my PC. Just follow these steps:
Simple as that. When this first started happening about 2 or 3 weeks ago, everything locked. I had to Hold the Power button for 10 seconds to shut down the PC. Once my computer restarted I tried several other programs on this PC and they worked fine. This gave me enough confidence to try Blender again.
I probably went through this same process 5 or 6 times a day for a week or more. When not on Blender I tried adjusting various Settings in Windows......eventually discovering that if I:
a) Opened Windows settings.
b) Clicked on Search
c) Clicked on Searching Windows
d) Looked at Excluded folders and took them out of the Excluded Folders category so that Windows could search them. Blender worked better, not great, but better.
Because of a to e:
First thing to change was I could move the mouse pointer around allowing me to go to the top right hand corner of the display to click X to close Blender, That was the end of shutting the PC off and restarting.
Also other changes have happened in the last 72 hours. I expect because of:
1.1 MS has made some updates
1.2 KB5004237
1.3 KB2267602 (Version 1.343.957.0)
1.4 Windows Malicious Software Removal Tool x64 - v5.91 (KB8980830)
1.5 plus whatever you Blender Folks have done in updating releases
Now after steps 1, 2, and 3, above I can RMB click and file unlocks. I can start working again on a new file, old file etc.
But: Working on a new file works fairly well. If I mistakenly click Circle Select I can just RMB click and carry on working on the file. However if I load an "old file" in Blender the file is very very unstable, making it just about impossible for me to work with.
Now I have to apologize..... I reported this with Task #89824. Which was put on hold waiting for further information from me. Task 89824 would not let me back in because I took to long to provide additional information, Also I could not provide a video or other information Blender wanted.
Steps as provided above under "short description of error"
Thanks
Lorne
Keep up the good work Blender folks!!
Added subscriber: @cmablend
Added subscriber: @crowe
The previous report is still open, you should be able to comment on it with more information, if not edit the original post. Also, please use descriptive titles.
I'm not sure what you mean by "LMC", but piecing info from you previous and current report the steps are:
Select > Circle Select
.Is that correct? If yes, I cannot reproduce the issue on either
62d9dabc7db4
norae379714e4f1
releases, which precede and come after yours.My suggestion is to do a
File > Defaults > Load Factory Settings
as startup files from previous builds can cause issues, including crashes. Also disable all your custom add-ons. If that doesn't help it might be an issue with your system. Check the Event Viewer for clues about what might be happening and consider updating or rolling back your graphics card driver.Changed status from 'Needs Triage' to: 'Needs User Info'
Closed as duplicate of #89824
@cmablend , please add requested information for #89824. Separate task for the same issue is not vey useful.
I will merge this report into
#89824
